Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Tire Pressure?
    Club Member 1BADAIR's Avatar
    cardboard box
    28,356
    Default Tire Pressure?
    I know suspension, weight , and power levels dictate tire pressure but what do most people use in 28/10.5/15's or 10.5s?
    Club Member TRBOBUICK's Avatar
    Jan 2000
    White lake , MI
    6,318
    Quote Originally Posted by 1BADAIR View Post
    Its a loaded question . Start at 15 psi and work up and down from there.
    Brian
    87 GN
    Club Sponsor
    W-town
    5,210
    with a heavy pig like yours 12-15 psi typically.
    Forum Member soap's Avatar
    Feb 2004
    In the garage
    6,243
    I run 10.25-10.5 hot (10.5S).
    --Joe
    With my car setup with the 5 speed, and a race weight of 3000 lbs, 12.5 psi seemed to work the best. It allowed for just enough slip to give us some wheel speed, preventing it from dead-hooking and dragging the engine down with the diaphragm style clutch. We used a 3055S M/T slick (28x10.5 stiff wall). We were leaving at ~7000 RPM.
    Hope this helps.
    Steve
    QuickLX.com
    Special Thanks to:
    Competition Components (Scott Brown)
    Hutch's Transmission Service (Hutch)
    Monson Racing (Jim Monson)
    Work Turbochargers (Reed Patridge)
    Club Member cjmatt's Avatar
    Jan 2006
    your mom
    15,088
    whats the difference between a stiff wall and wrinkle wall as far as launching is concerned. M/T makes both?
    Matt -
    2010 Boost Logic GT-R
    1983 Ford Fairmont
    Feb 2004
    In the garage
    6,243
    Quote Originally Posted by cjmatt View Post
    Stiff walls are typically for heavy cars or manuals that hit the tires real hard. They also provide better stability on the big end.
    Provided you get equal traction with both tires, the stiff wall will result in better short times since it will propel you forward instead of folding over on itself.
    --Joe
    cardboard box
    28,356
    the stiffs are just barely stiffer but like was said work better in heavy or manual cars
    Club Sponsor
    W-town
    5,210
    with SS slicks I'd going up on tire pressure. 12-15 is in the range most guys run. see any signs of shake in the tire ?
    Forum Member dante1120's Avatar
    Apr 2008
    East Tennessee/Hick life
    5,636
    11pounds 29-10.5 tire unless I want a to pull the front end off the ground for pics ill lower it to 9
