Originally Posted by
soap
Keeping the brakes is not a problem.
So do you simply want to run a 17" or are 16"/15" OK. If your only concern is matching front and rears then your options are next to nothing with the 17", because as you mention even the Alumastar doesn't have a great match for the rear, and they are almost $600/wheel. Maybe you can find a set of (front and rear) Greg Welds, those are 17".
16" you can do a Bogart, and they will weld the spacer right onto the wheel, 15" there are a bunch of options.
--Joe
