Results 1 to 8 of 8
Thread: Metal smoothing...
    Club Sponsor ReiKo's Avatar
    Workin
    39,889
    Default Metal smoothing...
    Last night cut out the core support and some of the engine bay...
    Once I grind down the sharp edges and make it all square... Any tricks or tips to smooth the metal out?
    Also with the area's I cut out in the engine bay... Best way to take the sharp edge off the metal? Hit it with a cookie disc? Or different trick?
    Quote Originally Posted by Admiral Isoroku Yamamoto
    “You cannot invade the mainland United States. There would be a rifle behind each blade of grass.”
    Forum Member Ozz's Avatar
    Jan 2010
    Canton
    1,841
    Cookie disc or flap wheel would work well. I used a flap wheel/grinder disc when I took out some of the ugliness of mine.
    Club Member moneypit's Avatar
    Jun 2005
    sony guts
    22,597
    hammer and dolley to make the area flat, lots and lots of tack welds "stitch" the replacement panel in place
    To me, it's a good idea to always carry two sacks of something when you walk around. That way, if anybody says, "Hey, can you give me a hand?" You can say, "Sorry, got these sacks."
    Forum Member vector006's Avatar
    Jun 2006
    116
    Agree, hammer and dolly and patience.
    Use angle grinder to knock off all the really sharp edges so you dont destroy your flexible wheel when you go to smooth out the edges. Use a sheet of bristol board to trace out the exact shape of the hole and use it as a template when you go to cut your 0.035 steel sheet. If you want to do it quick and dirty, cut the steel slightly larger and overlap the edges. Welding on one side, and seam sealing on the other, by doing this you'll be less likely to warp the panel when you stitch it together. Dont run a bead any longer than 1/2" at a time in each area. A panel that big is going to warp and distort. Bead rolling the panel would help mitigate that.
    Club Member supernotch90's Avatar
    Mar 2008
    BEHIND THE SPRAY GUN
    2,775
    Scott rod panels work real well, did it to mine ill get you some pics
    Club Member Anthony's Avatar
    Jan 2004
    I dont feel tardy
    9,985
    i have scottrods also.
    but if thats not your thing, you can buy replacement panels that are smooth already
    Club Member Way2Slow's Avatar
    Feb 2008
    Clinton Township
    610
    Scottrods is way simple and not bad on price vs. labor of all the time invested.
    REAL RACE CARS HAVE 3 PEDALS!!
    Not sure, but I think he is wayyyyyyyyy past the engine bay inserts now...
