Results 1 to 6 of 6
Thread: 89 Stang Brake setup question
    Club Member cjmatt's Avatar
    Jan 2006
    your mom
    15,088
    Default 89 Stang Brake setup question
    Im adding vacuum power brakes back to my mustang and was curious to the function of the distribution block. Do I have to plumb my linelock in between the master cyl and distribution block or after it? I also have an inline proportioning valve that previous owner installed in the line that runs to the rear brakes. Is that where it should be?
    Matt -
    2010 Boost Logic GT-R
    1983 Ford Fairmont
    A mysterious figure named Darko DarkoStoj's Avatar
    Mar 2005
    work
    9,114
    i'm not 100% sure but i think that inline valve you're talking about is a residual valve. You have rear drums? Does it look like this?
    http://www.summitracing.com/parts/WIL-260-1874/
    you can just put the line lock between the m/c and the prop valve.
    Jan 2006
    your mom
    15,088
    Matt -
    1983 Ford Fairmont
    Jan 2006
    your mom
    15,088
    I guess with rear discs, do I even need the factory prop valve? or can i just Y the line off the rear of the master to the fronts then thake the front master cyl port and run it thru my inline proportioning valve to the rears where it Y's to each rear wheel?
    Matt -
    1983 Ford Fairmont
    Club Member dave89iroc's Avatar
    Nov 2005
    Taylor, Mi
    16,273
    dont use the factory prop valve, line to the rear through the ad. prop., line to fronts through the line lock and tee the line after it
    Club Member black88coupe's Avatar
    Feb 2005
    YES my shit is slow and NO you can't drive it!
    6,886
    Did the wizard ever get back to you about that brain?????
