Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Will Fox suspension bolt into an SN95
  1. #11
    King of Bling.....Bitches!!! 2fastturbos's Avatar
    Jul 2006
    Dearborn Heights
    218
    Front struts from a fox are 1.5" shorter. all the mounting points are the same though. Lowered my 03 2" and switched to a fox strut because the factory ones would bottom out on big bumps.
    Michael Pinkowski A.K.A "Mini Mike"
    Moran Motorsports
    Wired 4 Speed
    MSL racing
  2. #12
    Club Member cjmatt's Avatar
    Jan 2006
    your mom
    15,088
    Ill give it a shot and see what happens.
    How about the steering rack? Ive got a manual flaming river rack on my fix Id love to put on the 2000, but I know they use different tie rods, is it just the threads that are different? Can I just unscrew the tierods a bit and run it?
    Matt -
    2010 Boost Logic GT-R
    1983 Ford Fairmont
  3. #13
    Club Member MentalMisfit's Avatar
    Sep 2009
    Roseville
    2,345
    if it's going to be that much lower from the struts you'll probably want a bump steer kit anyways.
    No More Projects
  4. #14
    Jan 2006
    your mom
    15,088
    Quote Originally Posted by MentalMisfit View Post
    who said anything about lowering it?
    Matt -
    1983 Ford Fairmont
  5. #15
    Sep 2009
    Roseville
    2,345
    If you end up using fox struts on it.
    No More Projects
  6. #16
    Forum Member STOCK GT's Avatar
    Dec 2004
    AT WORK :(
    4,488
    Fox struts will lower the 00 to a decent height compared to the Stock 4x4 look.
  7. #17
    Forum Member fpaultan's Avatar
    Dec 2004
    Newport, MI
    299
    A fox kmember will fit a 94-04 you just have to slot one of the holes on each side.
    Control arms are 1" shorter. I think fox control arms are 12" and sn95's are 13".
    I run fox length control arms on my 04 with a fox steering rack, flaming river 94-04 steering shaft and 94-04 Strange struts. works perfect.
    Hope that helps
    Frank
  8. #18
    Jan 2006
    your mom
    15,088
    Quote Originally Posted by fpaultan View Post
    Hope that helps
    Frank
    Thanks Frank, thats the kind of Info I needed! With the shorter control arms did you have to also run camber plates up top? any issues with camber being too positive? Id love to be able to run my fox manual rack also. what tie rod ends did you use?
    Matt -
    1983 Ford Fairmont
  9. #19
    Dec 2004
    Newport, MI
    299
    I have the Maximum Motorsports caster camber plates for 94-04. One thing I forgot to add was I used fox Racecraft 2" drop spindles. I did have stock fox spindles on it for mock up before I bought the Racecrafts and everything seemed to fit good with them. The Tie rod ends (bump steer kit) is PA Racing for a fox.
    Frank
