Results 1 to 7 of 7
Thread: will these fit a '66 or '69 5 lug mustang?
    Club Member wikdsvt's Avatar
    Mar 2004
    Just ahead of you.
    18,364
    Default will these fit a '66 or '69 5 lug mustang?
    Quote Originally Posted by Rich Christensen (PINKS)
    If you want to represent imports, don't ask for 20 cars
    Fun toys: his '99 Ford Lightning, hers '66 Mustang Coupe, quads, jet skis
    Official Motown Events Director Hugger Z's Avatar
    Feb 2006
    Harnessing 620HP up in Holly, MI
    11,411
    According to a database I found the 69-73 Mustang is 5x4.5" bolt pattern. And the 64-66 is the same 5x4.5" bolt pattern.
    And the wheels are 99-04 which also says 5x4.5 on the database. The only issue you may find is backspacing. My 99 Camaro rims fit my dad's 69 bolt pattern but the back spacing was way different. They tucked too far under the 69.
    Database I found for your reference: http://www.roadkillcustoms.com/hot-r...5&StudSpreadMM
    My Toys: Hugger Orange 1999 Z28 6-Spd Twin Turbo
    1937 Chevy Pick Up Extended Cab (1 of 1)
    Future Toy: Orange Ultima GTR or SLC...
    Oct 2008
    at home with the family
    5,226
    a friend put some 97 mustang wheels on a 69 he did have to use spacers but bolt pattern was the same
    Forum Member 1nine84GT's Avatar
    Feb 2009
    STUCK In marrage hell !
    2,028
    Im pretty sure the bolt patters will work but the problem may be with the back spacing. I know my 2004 Bullitts bolted to the back of a 73 Mach 1 but the fronts didnt fit because od the backspacing.
    Club Member OldbutNew's Avatar
    Sep 2010
    Somewhere in time
    2,494
    I would also check the hub bore diameters. Particularly if you DO go with spacers.
    The wheel forces are meant to pass to the hub bores, not just the studs.
    Club Member Billydroveit's Avatar
    Sep 2008
    Taylor
    5,967
    Quote Originally Posted by OldbutNew View Post
    All cars are meant to be hub centric, you can get hub fillers/spacers and most whel tire shops. I know when i was at belle tire we had them. Just takes a little measuring. SOme cars are more sensitive than others to this issue though, so most don't notice it.
    90 Red Fox Notch factory short block on 175Sold
    02 GMC Sierra 2500 ECLB Passsing everything but a gas station
    98 Cavalier 2.2 rusty but trusty
    www.SKUNKRACING.net
    Quote Originally Posted by 99slverZ View Post
    I will do actual slave labor for $25/hr. Literally I will wear a loin cloth and you can whip me for that kind of money.
    Mar 2004
    Just ahead of you.
    18,364
    thank you all very much!
