Results 1 to 8 of 8
Thread: Battery Relocation - What to do with the ground?
    Forum Member 5_Slow's Avatar
    Feb 2013
    Plymouth
    155
    Default Battery Relocation - What to do with the ground?
    This is the first time I've relocated a battery on any vehicle. I'm mounting the battery in the back of my Fox-body. I've been trying to read up to see what I should do with the ground. Some say just having the battery ground to the chassis, and another wire from block to chassis is good enough. Others say that you need to run a wire from the battery directly to the block. Which way is the right way? Will just grounding to the chassis work?
    Forum Member Randys88's Avatar
    Sep 2010
    shelby twp
    183
    Do a good short batt to chassis, I got a 0 gauge batt to the rear sub frame, and 3 from motor to chassis and works fine, if you have the stock motor ground straps id do one good motor to ground 0 gauge and see if it works, if it cranks slow or the ground gets hot u need more.
    Club Member TooSlo86's Avatar
    Sep 2011
    Mid Michigan
    1,063
    Pretty much same here. I have a short ground from the battery to the rear subframe and a ground from the engine to the front subframe, no issues for the last couple years.
    Feb 2013
    Plymouth
    155
    Okay. I wasn't sure if there would be any problems with that much current going through the chassis, but I'll give it a shot. Thanks for the help.
    Forum Member gdwrench's Avatar
    Dec 2012
    Westland MI
    371
    Shit, my whole dam car is a ground! ...lol
    Forum Member PUNISHER TA's Avatar
    May 2013
    Fenton
    49
    I did the same, but also ran a 0/1 from the battery ground to a starter bolt.
    I was worried about having low amperage to the starter when trying to spin over a High Compression 454
    Attach the ground to the roll cage, weld a bolt to it. Joe
    Forum Member 87droptop's Avatar
    May 2010
    Rocktown
    735
    Quote Originally Posted by torinojoe1971 View Post
    This is the best idea. If u weld a stud in the rear to the cage and go to the battery from it, then also weld 1 or 2 studs on you bar under your dash, it gives multiple points for attaching a good ground.
