Installed my k member. Coil overs and tubular control arms. I'm having a toe issue. Basically the wheels are pointing to the right with the steering wheel straight ahead. Using offset rack bushings in the correct position. Installed the steering shaft in the exact position I removed it and the rack was in the same position when the shaft was installed
