Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Team z front coil overs with strange struts
    Forum Member MarkVIII93's Avatar
    Nov 2009
    Allen Park
    2,887
    Default Team z front coil overs with strange struts
    Having a bit of a noise over larger cracks and bumps. Using single adjustable strange struts with strange coil over sleeves and 12/175 springs. Is this normal for coil overs?
    Nov 2009
    Allen Park
    2,887
    I've been reading that the strut rod is a smaller diameter than the sleeves of the cc plates. Using team z cc plates.
    Club Member Billydroveit's Avatar
    Sep 2008
    Taylor
    5,967
    If youre assembly is tight the slight diameter shouldnt be an issue. You removed everything that dampened noise from the front suspension. Just something you have to get used to.
    90 Red Fox Notch factory short block on 175Sold
    02 GMC Sierra 2500 ECLB Passsing everything but a gas station
    98 Cavalier 2.2 rusty but trusty
    www.SKUNKRACING.net
    Quote Originally Posted by 99slverZ View Post
    I will do actual slave labor for $25/hr. Literally I will wear a loin cloth and you can whip me for that kind of money.
    Nov 2009
    Allen Park
    2,887
    That's what I was thinking. Just want to be sure I don't have any issues
    Forum Member nitrouspete's Avatar
    Jan 2012
    newport, MI
    2,337
    check your brake line to coil over clearance. mine was close.
    Nov 2009
    Allen Park
    2,887
    The cobra brake lines clear.
    Club Member hangemhigh's Avatar
    Jan 2008
    Rivalry Czar
    12,271
    There's been some discussion on using a 14" spring to move the strut further up in the stroke, thus allowing a bit smoother ride. I'm not sure on the correct spring rate# for the 14", but I'd be interested in hearing anyone's opinion on this. Thanks.
    Btw, my son's '93 has 12/175's on it. Somewhat noisy and quite harsh best describe the ride.
    Nov 2009
    Allen Park
    2,887
    Quote Originally Posted by hangemhigh View Post
    My thought also. But I've kinda thrown nvh concerns out the window to a point
    Forum Member Strlegal's Avatar
    Jan 2008
    Waterford, MI
    38
    I experienced noise with mine from the spring rubbing on the collar from the coil over kit . Can't hear it over the engine, but pushing on the fender when parked you can hear it at times. I heard this is more common with 14" springs then with 12", because the 12" will have less side to side flex/bowing, and it moves the center of the spring higher above the body of the shock where the most movement would be.
    Mike
    Club Member svtserpent's Avatar
    Sep 2008
    1,884
    Mine make lots of noise.
