Page 16 of 24 FirstFirst ... 6121314151617181920 ... LastLast
Results 151 to 160 of 237
Thread: Turbo Mark VII Time
  1. #151
    Club Member Duke's Avatar
    Southgate
    3,315
    That's lookin real good!
    I like pie.
  2. #152
    Nov 2009
    I think I have a Prius stuck in my intake.
    1,828
    Figuring out the order to bolt all this crap together sucked but, the brake pedal, booster, steering column and all that jazz is finally in the car for good. Though, now I see just how dirty everything has gotten.
    BCN_4497 by Jason Bacon, on Flickr
    BCN_4487 by Jason Bacon, on Flickr
  3. #153
    Nov 2009
    1,828
    I'm not sure if the cuts are worth it but, I guess the illusion of the door feeling has much as the other does. There is still some to cut out and some trimming to do but, that's for tomorrow.
    BCN_4512 by Jason Bacon, on Flickr
    BCN_4509 by Jason Bacon, on Flickr
  4. #154
    Nov 2009
    1,828
    The camber/caster plates came in today so, I had to toss them on to see what they look like. I also tossed on the mock up Strange struts since they didn't fit the stock strut mounts. All I know now is, full droop is what ride height use to be.
    BCN_4522 by Jason Bacon, on Flickr
    BCN_4523 by Jason Bacon, on Flickr
  5. #155
    Nov 2009
    1,828
    Decided to toss the fender and a wheel on, to see what it will look like if, it ever stands up.
    BCN_4527 by Jason Bacon, on Flickr
    BCN_4528 by Jason Bacon, on Flickr
    Holy shit, I made something! I mean, it's complete crap but, you have to start at crap to make it up to garbage...right?
    Got the Flaming River rack in the other day so, that got tossed into the car and, I made the steering shaft. It looks like I need to go to the store and get another set of outer tie rods for this rack. When I de-powered the factory rack, I switched over to all SN95 stuff and this rack, uses Fox based parts. I should have read up a bit more before assuming it would all go together magically.
    BCN_4864 by Jason Bacon, on Flickr
  6. #156
    Nov 2009
    1,828
    Put the new outer tie rods on, tightened up all of the suspension for the first time and set it down. I may need to put Fox length control arms on up front, to suck the wheels in a bit more.
    BCN_4877 by Jason Bacon, on Flickr
  7. #157
    Nov 2009
    1,828
    So, I took advantage of the semi warm weather and dusted the car off. The water that came off of it, was worse that most rest stop toilet water.
    Washed (1 of 8) by Jason Bacon, on Flickr
    Washed (2 of 8) by Jason Bacon, on Flickr
    Washed (3 of 8) by Jason Bacon, on Flickr
    Washed (4 of 8) by Jason Bacon, on Flickr
    Washed (5 of 8) by Jason Bacon, on Flickr
    Washed (7 of 8) by Jason Bacon, on Flickr
    Washed (8 of 8) by Jason Bacon, on Flickr
  8. #158
    22,841
    Looks awesome, the stance is sweet.
  9. #159
    Club Member 4Gas$'s Avatar
    Milan
    10,692
    Cool
    A very cool build indeed! Really want to see (hear) this
    thing come to life!
  10. #160
    Club Member BigWheelinBubba's Avatar
    North
    21,008
    Still following... every little step is a step towards bad assedness!
