Having trouble getting all the air out if my brake lines. I bought a power bleeder which worked, but when you remove it and replace the master cylinder cover, the pedal softens up again. Granted it pumps up after one cycle of the pedal, but still not right.
There are no leaks in the system. When the system is pressurized with the power bleeder, there is no decrease in gauge pressure. I'm stumped? I've also changed masters twice, changed front calipers, rear wheel cylinders and lines a few times chasing this.
1) Should there be any pre-load on the pedal pushrod? I have it touching when the pedal is at rest, but no load on it?
2) should the master cylinder lid have a vent on each side (this is a metal clamp style) or should it seal tight?
If anyone wants to take a swing at this thing, I'll pay you. I don't want to piss the summer away chasing this.
Chris
810-429-6446
