I figured I would post here first. I'm going a different direction with the car.
-8.2" Dart Iron Eagle block 4.180" bore 55mm roller cam bearings ARP main studs & bolts billet 4bolt caps on all 5 mains
-Callies Ultra Billet 3.4" crank - zero balance
-GRP 5.4" Rods
-Ross pistons, coated, 14:1
-Danny B belt drive
-.920int/.927exh 55mm cam from Bennett
-Jesel .905 tool steel tie bar lifters
-Fox Lake stage 4 TFS "R" cylinder heads
-Crower custom steel shaft mount rockers
-Hogan billet runner TP top manifold with rails/injectors
-Nitrous Pro Flow 2 stage plate flowed with jet chart and tune ups
-Wilson 4150 throttle body
-Custom stainless 2" stepped to 2 1/8" with 4" merge collectors made by Diamond
-Canton aluminum pan
-ATI super damper with timing pointer
Extras:
-8 spare pistons
-Cast Victor 8.2 ported by Wilson manifold
Asking $17,000 for everything
If you have any questions feel free to ask.
