Just as the title says...im looking to find out the correct Backspace to fit a 12" rim under my car. the car has mini tub done and coilovers.....im hearing anywhere from 6" to 7.5" BS when i have done some searches on other forums...thanks guys
Depends on if and how much the rearend has been shortened
Typically, if it's a fox rear end in a fox car and it's been shortened until the 9" end is all the way against the lower control arm mount, the car will use a 15x12 with a 6.5" backspace. Some will also use a small spacer, depending on the tire being run.
11 Mustang GT (street car)
87 Grand National (grudge car)
Misc old Ford street cars
I've seen it done with a 7.5" backspace wheel on a 10" rim, but not a 12. Take 2.5" off the axle and use a 6.5 BS 12" wheel like Raj said. If you're going to stretch a 28x10.5 tire on there you can get away with only 2" off the rear. To run a W tire or more you need the extra 1/2" off the axle.
I tried a 7.5 backspacing on a 12" rim but it stuck out too much. Keep in mind the crazy backspaced rims have a weird barrel shape that won't allow some brakes. My wilwood's would fit. Not even close.
01 EXCURSION
11 RUBICON black ops
82 MUSTANG GT
75 Porsche 914
33 will be fine for that power range, but at 1500, you will probably destroy the 33s and need to go to 35s. Also for the 12" with 6.5" bs, bring the 9" end all the way to the lower control arm mount. That distance may vary depending on the rear end, but it is likely around 2-2.5".
There are currently 4 users browsing this thread. (0 members and 4 guests)
