Results 1 to 4 of 4
Thread: 95 mustang - decent traction/axle anti-twist bar?
    Club Member wikdsvt's Avatar
    Just ahead of you.
    18,305
    Default 95 mustang - decent traction/axle anti-twist bar?
    I'm putting some slicks on a 95 mustang.
    I need to prevent the rear axle from twisting. The car is still street driven, full power accessories, a/c, etc...
    What is a good traction bar that won't interfere with the way it rides during normal use, which is 90% of the time.
    Quote Originally Posted by Rich Christensen (PINKS)
    If you want to represent imports, don't ask for 20 cars
    Fun toys: Banshee (x3), KFX 700, '66 & '70 Mustang, '99 Lightning
    Forum Member soap's Avatar
    Feb 2004
    In the garage
    6,239
    Quote Originally Posted by wikdsvt View Post
    Any anti roll bar is going to interfere with the way the car rides, if it doesn't then it isn't doing the job it is intended to do. Just depends on how much the owner is willing to put up with for a street driven car.
    UPR, Team Z etc are good weld in bars. MM makes a bolt on kit too.
    --Joe
    Feb 2004
    In the garage
    6,239
    Just reread your post. An anti roll bar will help with traction but won't help with axle twist. You need to weld the tubes and add bracing to prevent axle twist. CHE makes a bolt in kit, but some weld on supports would be better.
    --Joe
    Club Member Billydroveit's Avatar
    Sep 2008
    Taylor
    5,963
    Team Z has a great street series set up thats absolutely awesome. Anti roll bars aren't exactly street friendly, but running an aftermarket anti sway bar works good too. You will suffer some ride quality,but his has bushings in them still so better than solid. You don't really have to worry about axle tubes twisting untill you hit serious power levels. I've seen cars well into the 9's and 8's without tubes welded, but Team Z also sells a nice axle brace kit too.
    http://www.teamzmotorsports.net/Stre..._p/tzm-sb3.htm
    90 Red Fox Notch factory short block on 175Sold
    02 GMC Sierra 2500 ECLB Passsing everything but a gas station
    98 Cavalier 2.2 rusty but trusty
    www.SKUNKRACING.net
    Quote Originally Posted by 99slverZ View Post
    I will do actual slave labor for $25/hr. Literally I will wear a loin cloth and you can whip me for that kind of money.
