I'm literally selling everything, entire car, all the parts, trailer, welders, some of the larger shop tools etc.. I'm going to constantly be updating and adding stuff to the list as I dig out more stuff in the garage and as things sell.
All parts are located in Lincoln Park, MI 48146. I will ship items that are box-able for the cost of shipment. I will deliver the car to buyer and the trailer for trip fuel costs.
For pictures of anything listed please text me at 734-307-4029 I will try to get pictures of everything posted but it will take some time to get them all uploaded to the Photobucket account, then i will add a public folder link here to view them.
Reid Case powerglide. 1.80 straight cut billet gear set, vasco input, 8 clutch fwd drum, wide band, alto reds throughout, pro brake, deep pan, overflow catch bottle and line. Roller tail shaft, BBF Bellhousing. Trans has 5 passes on it - $3500.00
Cameron Converters Powerglide to BBF converter (turbo spline). This was used behind a ~2400hp BBF TT motor. Converter is nothing shy of incredible can build up to 4500+ on break and it locks up crazy tight down track. Has 40 1/8 mile hits on it. - $1200.00
Danny Bee belt drive. Complete - has 40 1/8 mile passes on it. $800.00
MSD crank trigger kit for BBF - $250.00
Trick Flow 1.73 roller rockers BBF - $250.00
A460 single plane intake - EFI converted w/fuel rails powder coated black - see for sale add on here. $750.00
http://www.460ford.com/forum/showthread.php?t=219889
Moran matched set of 9 - 500lbs per hour injectors. 40 1/8 miles passes. - $2500.00
MRE spec 10 micron fuel filter - $350.00
Two S475 turbos 1.32 housings w/40 1/8 mile passes - $650 each
A460 heads - New style 87cc, 10 bolt, one head has a chamber damaged from piston contact due to rod failure. head guy quoted 400 to fix. $2200.00 as is for the pair or I will re-list after I get around to having them fixed.
ARP 18 bolt head head stud/bolt kit - $240.00
Skinny kid BBF mid plate .250 thick aluminum for on center in foxbody. - $100.00
KeithFulp belt drive front motor plate with spacers and timing tab - $150.00
Aeromotive black atomic pump 11115 with mount, drive pulley and belt - $750.00
http://www.summitracing.com/parts/aei-11115
Aeromotive belt drive high flow EFI reg - $200.00
http://www.summitracing.com/parts/aei-13113
Set of 8 Delco D585 LS coils - $220.00
Price motor sports - Part No. CS-351C/M/429-B w brass gear + “Hall Effect” 3 prong electronics - $240.00
TCI outlaw two speed shifter with cover and grip switch plate - $320
http://www.jegs.com/p/TCI/TCI-Outlaw...57631/10002/-1
Lincoln 180HD welder with cart, one year old and I will include a new industrial size 25%mix bottle - $600.00
Dart Pro One CNC SBf heads - $2000.00
SBF CSI electric water pump (red) - $180.00
Victor Jr SBF intake 9.5 deck(351w) $200.00
B&M holeshot converter Glide with turbo spline to BBC 3200-3600 - $300.00
Powerglide cast aluminum deep pan with filter spacer - $100.00
Two Wynton Ebay 60mm wastegates - $120.00 for the pair
Down and FWD turbo headers BBC style flange - $400.00
Much more to come...
