List of stuff as follows
5.0 alternator bracket with tensioner, alternator, smog pump and hardware. The smog pump still works great all stock take off including the smog canister and lines. $75
Aftermarket heavy duty flywheel barely used great condition with appropriate fasteners $70
4 row aluminum radiator with electric fan and adjustable thermostat all wiring intact hoses all included ready to install plug and play $200
Edelbrock SBF mechanical water pump works perfect lightly used $50
Stock mechanical water pump work good $25
Ford racing aluminum drive shaft super low miles bolt it in and drive home $175 e
D&D 5speed low miles like new both in appearance and operating $1100
Includes billet short throw shifter bellhousing and aluminum shim plate.
Stock starter (Large style) works perfect $20
Complete A/C system no leaks works as it should everything from condenser to compressor $100
Mass air Meter aftermarket large size unsure of MM? Complete with K&N and inlet tube came off running car. $75
Full 10lb nitrous bottle with bottle blanket $150
Trick flow heads $1500
2 hydraulic cams unsure of spec but have grind numbers on them both are comp cams $50 each
1 hydraulic flat tappet with lifters and timing set hardly used dyno and 300 street miles XE284H-10
$80
Sport comp Auto meter Tach with light $70
Please no ridiculous offers I will bundle items went to an LS setup this stuff is sitting
586 two four three fiftyone forty
