Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 1960 Baja
    Club Member TWOBEERS's Avatar
    Nov 2007
    Roseville
    735
    Default 1960 Baja
    This has been a long term, on again, off again project that I just have to get done. I bought the body for $400 when my oldest son was in junior high. He's now an electrical engineer for Harmon Kardon. That's how long its been hanging around. Between working way to much, a side business, and my street car that always to get first dibs, it doesn't get much attention. Anyway, my intention is to have it built far enough to put an ORV tag on it and be able to trail ride it by next spring. Initially it will be an almost stock 1600 air cooled that I will be building over the winter. Eventually it will either be a big turbo air cooled, or possibly a GM ecotec, or a TDI diesel vw. It also has a 094 bus trans, and roughly 16" of wheel travel at each corner with racerunner coilovers. So next is a lot more cage work, suspension work, and enough electrical and mechanicals to make it trail worthy. After that winter projects to finish it up. I am by no means a fabricator. But can struggle through it. Anyways, here's some pics and I will try to update it as it slowly moves along.
    Attached Images Attached Images
    Not a mustang!, 84 TransAm street car! 350 SBC on E85, Dart heads, T400, ford 9"
    Club Member JoeP.'s Avatar
    Nov 2007
    Tecumseh, MI
    1,526
    This is sooooo badass!! I love it.
    Club Member black88coupe's Avatar
    Feb 2005
    YES my shit is slow and NO you can't drive it!
    6,886
    Hell yeah!
    Did the wizard ever get back to you about that brain?????
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    That is insane travel! If you want a 2007cc turbo VW built with top of the line parts, get ahold of me. I drag raced it all day today, 12 passes without a hickup but I am looking to swap in a different setup.
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
    Forum Member Falcon64's Avatar
    Aug 2011
    Monroe County
    1,697
    Cool project good luck
    Nov 2007
    Roseville
    735
    Thanks for the comments. Yea, Horsepower is useless offroad without the suspension setup to handle the terrain. That motor definitely sounds really interesting.
    Nov 2007
    Roseville
    735
    Thought I would give some updates. I've made some good progress with the cage. Probably around 80% done. I wasn't happy with the position of the front axle beam. At full turn the tires rubbed on the inner wheel wells. So I cut off the factory mount and moved the whole thing forward 7". It set the project back a bit. But needed to be done. Some other projects have gotten in front of this so it will probably be a couple months before I'm back on it.
    Dearborn
    6,003
    Built tough!
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
    7,215
    This is bad ass
    Club Member capone's Avatar
    Apr 2008
    Clinton Township, MI
    2,524
    Cool project, Awesome fab work.
