Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 56
Thread: looking for the LED's for garage
  1. #11
    Club Member moneypit's Avatar
    Jun 2005
    sony guts
    22,597
    PM mike 347convert he has them, I finally got mine wired up proper last night only been 3 years
    To me, it's a good idea to always carry two sacks of something when you walk around. That way, if anybody says, "Hey, can you give me a hand?" You can say, "Sorry, got these sacks."
  2. #12
    Forum Member Detroit Gearbox's Avatar
    Jan 2007
    Warren Michigan
    4,912
    I think I bought 40-50 4' clear bulbs.... knock on wood not one had failed.... I turn them on 6-7 days a week 8-14 hrs a day.
    I need to change out every bulb in my garage at home..... what mounting ends do you guys use? ... and I think I read you guys connect end to end... what connectors have you guys found to be the best?
  3. #13
    Jun 2005
    sony guts
    22,597
    they come with a connector to daisy chain them, the newer connector is longer so it works much better. for the outlet end I use "mickey mouse " power cords
  4. #14
    Club Member
    Oct 2006
    Troy
    4,274
    Quote Originally Posted by moneypit View Post
    Do you have any spare long style connectors I can try before I throw out the non-working lights again?
    Gary
  5. #15
    Club Member beertestr's Avatar
    Feb 2005
    F-Hills
    2,670
    Quote Originally Posted by grr456 View Post
    Ken,
    I have thrown (2) away already and haven't gotten around to replacing these 3....It could be the connector, but I have tried wiggling the light and nothing. On the first ones which failed, I hooked them up directly to the lead wire and still didn't work.
    Gary
    Attachment 80306
    I'd put money on the connector M-M connector. One of mine takes a tap to turn on. I've roughed in 6 outlet boxes in my garage, and will likely just plug each fixture into an outlet individually.
    Mike
    99 Ultra Classic, 89 Softail, 67 Kaw 250
  6. #16
    Feb 2005
    F-Hills
    2,670
    Quote Originally Posted by PRDATOR View Post
    Does anyone still have the led's for sale? I plan on using them in my garage. I will need to know lumens, length of led's and so on. I have 10'6" walls, with a ceiling height of 15', so I will need to know if these led's will throw adequate light to the floor. If they will work, I will need enough to cover 34'x56'. I am also looking for two motion flood/security lights for each outside end of the garage. Thanks.
    Attachment 80304
    Awesome build,have you considered floor drains?
    Mike
  7. #17
    Feb 2005
    F-Hills
    2,670
    Attachment 80304
    Mike
  8. #18
    Feb 2005
    F-Hills
    2,670
    Cut and paste from an older thread on the lights. You can chain 5 together, total power for all 5 is 200W.
    Pics below are with 1 single light in an otherwise completely dark shop. I am sure they will light better once I get the shop boarded and painted BRIGHT white.
    Very low profile, screw them right to your ceiling. They only weigh a few oz. each
    Below is a comparison of 1 fixture in my garage, only source of light.
    Testing.... i held the LED fixture right beside the t12 fixture for comparison.
    2 bulb 40W T12.
    Single 4 ' LED
    Mike
  9. #19
    Jun 2005
    sony guts
    22,597
    I currently have 4 rows of 8 in my garage zero issue
  10. #20
    Jun 2005
    sony guts
    22,597
    Gary
    Let me look , i did have one "bad" fixture. Turns out the end was loose. You still in novi for work?
