Results 1 to 8 of 8
Thread: 99-04 switched 12v under dash fuse?
    Club Member cobrarwanab's Avatar
    Mar 2007
    Dearborn Heights
    2,711
    Default 99-04 switched 12v under dash fuse?
    I'm looking to add a digital volt gauge/usb power supply in place of the stock 12v power socket located in the shifter bezel on my 2002 mustang gt. The power needs to be fed from a "key switched" source. I bought a "add a circuit" connector that can handle 10a although it will only see about 2.4a. My question is- anyone know what fuse under my drivers side dash I should piggyback for a key switched source?
    7,215
    cig lighter?
    Forum Member
    May 2008
    Rochester Hills
    2,464
    Cigarette socket is always on. I know there are fuses under the drivers side dash that are key on 12v only as Ive used them to tap the 12v signal wire for my intercooler and fan relays. You'll just have to look at the manual and find one.
    Forum Member soap's Avatar
    Feb 2004
    In the garage
    6,243
    Quote Originally Posted by 93 saturn sl2 View Post
    The manual won't tell you which circuit is keyed on.
    OP, just pull a fuse a stick a test light in the socket and cycle the key. Shouldn't take more than a few seconds to find one that will work.
    --Joe
    Mar 2007
    Dearborn Heights
    2,711
    Quote Originally Posted by soap View Post
    --Joe
    I'm fat these days an it's getting harder to twist myself up under the dash to test. I'll stop being lazy and grab my volt meter lol.
    Here i am, what are your other 2 wishes?
    Feb 2004
    In the garage
    6,243
    Quote Originally Posted by cobrarwanab View Post
    LOL, understood. Good luck!
    --Joe
    7,215
    I couldn't remember on the SN95s, some cars have keyed cig lighters.
    Forum Member
    May 2008
    Rochester Hills
    2,464
    --Joe
    True, but you probably know what circuits work when the car is on vs when its off and the manual will tell you what circuits each fuse controls.
