Craftsman 28 piece set is from the 70's and has been well used. Some of the taps have been replaced
Basic Sizes - 1/4 to 1/2 taps and hex dies and 1/8 and 1/4 pipe - Missing one tap handle
All USA made - $30
Interstate 110 Piece tap and Die Set - 2 years old
SAE and Metric - Everything you'll ever need up to 3/4"
All the common and hard to find inch and metric taps and dies you’ll ever need.
- Metric size dies and taps 5mm-18mm
- UNC (USS) inch dies and taps #4-3/4 inch
- UNF (SAE) inch dies and taps #10-3/4 inch
- hard to find 1/4-24 and 1/4-32 dies and taps
- 1/8 inch NPT pipe thread tap and die
- 1/4 inch NPT pipe thread tap
- 3 tap wrenches
- 2 die handles
Running around looking for an uncommon thread size tap or die in the middle of a project is a real hassle. This set has all the usual taper and bottoming taps, and matching dies, plus many hard to find sizes. You’ll save money too, compared to the price you pay for each piece if you were to buy them individually at your local retailer. This set comes with 9 taper taps, bottoming taps and dies in metric sizes from 5mm to 18mm, 13 course thread (USS) inch size taper taps, bottoming taps and dies from #4 to 3/4 inch, 6 fine thread (SAE) inch size taper taps, bottoming taps and dies from #10 to 3/4 inch, taper and bottoming taps and dies in the hard to find 1/4-24 and 1/4-32 sizes, 1/8 inch pipe thread (NPT) tap and die, and handles.
I bought this set from MSC for about $225 and it has gone up quite a bit...
https://www.mscdirect.com/product/details/03959137
But now Eastwood sells the same thing for $125
http://www.eastwood.com/eastwood-110...d-die-set.html
Missing 3 taps and the large handle is broken - See picture...
Made in China - I want $75
Located in Troy
rce789@yahoo.com
Gary
