Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: 2016 Diesel F350 vs gas? costs?
  1. #11
    Oct 2003
    Metro Detroit, MI
    15,478
    Quote Originally Posted by moneypit View Post
    remember 99% of americans buy a truck to do something with it thats is only done 1% of the time
    Being awesome counts as a thing! 100% of the time driving that!
    2016 Camaro Convertible 2SS
  2. #12
    Forum Member RSWANNABE's Avatar
    Mar 2005
    Roseville
    3,924
    The diesel pays for itself the first time you push the pedal down. I'm sure resale is much better too.
  3. #13
    Club Member OldbutNew's Avatar
    Sep 2010
    Somewhere in time
    2,494
    That kind of deal on a 6.7 Powerstroke would be hard to pass up. You plan to keep it 3-4 years and not rack up big miles? Look at what 2012 and 2013 diesels are going for. The resale difference between gas and diesel needs to factor in. Sorry that one sold. If you find another one...
    Is it just me, or is the United States of America going further and faster downhill by the day??
  4. #14
    Club Member Stormy81's Avatar
    Apr 2007
    732
    If you do decide to ante up and get a fifth wheel later on, diesel all the way sir!
    Just another deplorable American...
  5. #15
    7,215
    I went from an F250 to a 2013 F150 3.5TT. I did not enjoy the 14 qt oil changes and expensive filters. Oil filters were $25 each and fuel (every other oil change) was like another $40. You get bad diesel one time and kiss your fuel system goodbye.
    Diesels are excellent if you're towing. I mean towing a fuckton. Max tow equipped F150s can tow 14k or so. The payload is the biggest trade-off. Do you want a more nimble softer riding truck or stiffer bigger truck? It all depends on use and how long you are planning on keeping it.
  6. #16
    Forum Member 99Electriccobra's Avatar
    Dec 2007
    Northville
    1,637
    Thanks for the feedback. Thinking I may hold off til next spring. I wouldn't be towing a "fuckton" but want a truck bigger than an F150 on the road. A 6.2L gasser F250 would probably do me just fine. Current set up, but if I had a 3/4 ton, wifey would probably push for a 5th wheel. Current camper is 28 feet, around 7K.
  7. #17
    Club Member derbydad276's Avatar
    Oct 2008
    part time Yooper
    5,098
    been there done that with campers .... I started out with a 20 foot moved up to a 28 and then to a 31 footer
    big mistake.... became hard to find camp sites big enough if you are going to travel stay with a smaller trailer
    I used a E350 clubwagon as my tow beast with a V10 never ran out of power got 16 mpg hiwy solo and 10 mpg towing
    just my 2 cents worth
  8. #18
    Forum Member
    Dec 2003
    147
    I daily drove a 2013 F350 CC LB diesel for 4 years and am now driving a 2017 F350 CC LB Diesel. I don't tow much, but when I do pull the 32' enclosed trailer, this truck made it easy. Everyone that rode in the truck when towing was impressed. Yes, the ride was firm when running unloaded, but settled down with a few people and/or cargo in the back. I also wanted a crew cab with an 8' bed so I can avoid using a trailer sometimes by having enough room for what we need to take. My fuel economy, even when towing is better than my previous half-ton Chevy. Certainly better than an F350 with gas engine when towing.
    Oil filters (OEM Motorcraft) are ~$13 or less if you buy a few at a time. Oil is not too bad depending on what you use, but still ends up costing $80 for an oil change with filter if you do it yourself with T6 oil. As mentioned above, once you push the pedal, it makes it worthwhile.
    I justified it due to the main cost difference between similarly equipped F150 and F350 w/6.7L was basically the cost of the engine. Much of that is made up on resale and I ended up with a much more capable truck. If I would have gone with a gas engine, I might have stuck with an F150, but everyone's situation is different.
  9. #19
    Club Member nitrousrick's Avatar
    Mar 2004
    Northside
    5,136
    I can't even imagine how bad it must suck pulling 14k with a half ton truck. You can put whatever rating you want on it but I'd have zero interest in ever pulling that much with a half ton. I have a 2004 2500HD with a duramax and even pulling my lightweight 33' 5th wheel(8k dry 10k gross) with a 35 mph headwind makes the truck work if I try to pull at 70.
    84 Mustang Coupe
  10. #20
    7,215
    Quote Originally Posted by nitrousrick View Post
    It really isn't too bad with the turbos but if I were constantly towing a heavy trailer I would opt for a 3/4-1 ton truck
    The 2017 F150 with the 3.5 TT is 12,200 lbs. IDK why I was thinking 14k.
