As a reminder - I can run your distributor on my Sun 504 Distributor Machine. Drop your distributor off at my house and pick it up a few days later. I'll put a curve kit in it, if you bring it to me.
I have the Tune-up specs for many original 60's - 70's cars if you want it brought back to original specifications. If you have a GM dist, there is a 99.9% you will need the limiter bushing if you haven't replaced it. Buy an MSD advance kit if you want a curve kit installed. The Mr Gasket ones are junk. Make sure the kit includes the limiter bushing.
I can do most distributors, including MSD and HEI distributors. I cannot do the late model fully electronic distributors for fuel injection. I can also check your vacuum advance unit.
I do this as a FREE service, since everything else is so expensive. Just bring or order needed parts.
PM me for my address - I live in Troy, Mi
Gary
