Up for sale is a Ford PIE adapter for 01-03 Mustangs (will fit other Ford vehicles with the "world" connections aka the black connections). I had this installed in my 99 Explorer, using the radio out of my 2002 GT w/ Mach 1000. Just press the CD button twice and it will go to "DJ" mode. These are hard to come by now. Makes a great way to add aux-in without having to install a new radio.
This is almost plug-n-play as it sits. Just need to tap the accessory 12v+ from the radio harness and connect the negative to the spade connector on the back of the radio and you'll be up and running. The Blackberry Gateway gets power from the USB connection.
Im willing to sell the setup in two ways:
The PIE adapter alone for $75
The PIE adapter w/ usb plug and Blackberry Bluetooth Music Gateway for $110.
Vehicle Compatibility in the link below.
https://www.sonicelectronix.com/item...-FRDN-AUX.html
