Results 1 to 6 of 6
Thread: 1990 Mustang
    Forum Member EFIAlex's Avatar
    Jul 2008
    Michigan
    337
    Default 1990 Mustang LX 10point Rolling Chassis
    It is with great regret that I am selling my 1990 Mustang LX. With an upcoming wedding, my priorities
    have shifted. Car has 46k original miles. I had plans for this to be an 8-second turbo car and started
    building the chassis. Car is very solid and rust free. It has never been raced and was stock when I
    purchased it. Car has clean title.
    Asking $9,000
    Text or call 734- s3ven six 5 - 7753 (located in Woodhaven)
    Notes:. Rear end is installed dry (no fluid). No rear brakes; brake line is capped.
    Engine/Trans:
    · Stock 302 original engine/mileage
    o MSD 6AL
    o MSD Coil
    o AC Delete pulley
    · 3g alternator conversion
    · Stock AOD original transmission/mileage (unmodified)
    Chassis:
    · Diamond Race Cars 10 point chrome moly cage with window net and removable parachute mount
    · Stroud single shut with spring launcher
    · Diamond Race Cars through the floor sub frame connectors
    · Reinforced torque boxes, spot-welded seams with Wolfe Race Craft lower plates. Cage is tied to upper torque boxes for extra reinforcement (cage goes through the back floor).
    · 5 point harness mounts
    · Coil over conversion (QA1 single adjustable)
    · Team Z Anti-roll bar
    Interior:
    · Car comes without front seats.
    · All original interior panels not pictured are included with the car. Car has original black interior. Also, have back seats to go with car.
    · New black carpet with padding removed
    · Autometer 5 inch tach
    · AEM Trans temp gauge
    · AEM Oil Pressure Gauge
    · B&M ratchet shifter with custom trans brake button.
    · Grant Steering wheel (horn still works)
    · All factory gauges and lights work
    · Heater core and heat is fully functional; AC has been removed
    · Radio deleted. Switch panel in place of radio
    · Battery relocated to the trunk
    · Flaming river push/pull kill switch
    Rear end:
    · 8.8 rear end housing
    · 3.27 Ford Racing gears
    · 35 spline Strange axles with 5 lug 5/8 th studs
    · Strange Spool
    · Racecraft 8.8 Stock style lower control arm housing adjustable bracket kit
    · Racecraft 8.8 axle tube brace kit
    · 9 inch big axle ends
    · 1350 yoke
    · Trickflow diff cover with bearing supports
    ·Team Z upper and lower control arms
    ·Team Z upper control arm relocation kit
    Body:
    · No rust anywhere, no bubbles, surface or anything!
    · Rear hatch factory spoiler deleted
    · Strut towers, frame rails and torque boxes all rust free
    · Racecraft strutless wing; color matched to car
    · Rear wheel wells enlarged for 29.5 inch tire fitment (looks factory)
    Jul 2008
    Michigan
    337
    price drop. Also got some front rims. Trying to make it able to roll/drive.
    Jul 2008
    Michigan
    337
    Need to get this gone
    Jul 2008
    Michigan
    337
    Car is a roller now
    Jul 2008
    Michigan
    337
    Price update
    Forum Member 69 mach's Avatar
    Feb 2009
    Sylvania, Ohio
    1,212
    Looks good glws
