Can a transmission case be welded ? If yes looking for referals.
Yes, depending on where it needs to be welded. If re-machining is needed after welding it might not be worth having done. If it's just a crack in the bell housing or any other external surface I don't think it would be a problem. Call Chris Razor at High tech welding in Ypsilanti I think. The guy can weld wood. I've seen him do it.
I used to be 'with it'. Then they changed what 'it' was. Now what I'm 'with' isn't 'it', and what's 'it' seems weird and scary to me.......
1948 Dodge B1 pickup
Thanks, just need a address to show up. Did a search can't find it.
Carters welding 313 849-1610. It’s my brother he does them all the time.
pm sent
Post a picture.
Ill tell you if its feasible/worth welding.
My guess is that you have to have the trans gutted and the case cleaned too, if you want to get it welded good. Unless a little edge piece or something broke off.
2016 Camaro Convertible 2SS
It depends where the crack is, he has a hoist so it’s possible. A pic would help to determine for sure.
