Do we have any bicycle folks on mm that know a lot about parts?
Have a trek 8.3 and the fork as well as stem parts are discontinued. Personally I'd rather upgrade the innards of the current fork that currently uses a spring with lockout to something more robust that will not compress when in the lockout setting. Wouldnt mind a multi stage setting but on or off will suffice.
The stem is the most unknown. What are the proper parts? Being a 2012 model, it is threadless. Just not sure what I'd all need during the overhaul? Are there full stem rebuild kits available that will include 100% everything?
I have done threaded stems in the past, & replaced fixed forks with no issues... hell i lace, true, & tension my own wheels & service the bottom bracket when needed... why wouldn't i do my own stem & suspension fork?
