Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: Surging idle on a stock 5.0
    Club Member derbydad276's Avatar
    part time Yooper
    5,098
    vacuum leak ?
    Vacuum leak, failing fuel pump, IAC
    Club Member Anthony's Avatar
    I dont feel tardy
    9,985
    Iac has passed all tests.
    Searching for a rail adapter
    Sprayed everything down
    Can’t find a vac leak
    Club Member sidewayscoupe's Avatar
    275 and 94
    9,287
    Default Surging idle on a stock 5.0
    It’s that X cam causing your grief ;-)
    https://lmr.com/item/LRS-9939A/1986-...SABEgLOGfD_BwE
    Sent from my iPhone using Tapatalk
    HI 5 Racing
    Aug 2010
    No Spin Zone
    2,912
    You can get the 1/8 to 1/16NPT at Parker, or Exotic fittings. I actually just bought a couple last week, their about $12.50 each. If you need one I have a spare...
    I'm talking the fuel rail adapter, I put the adapter on my rail to install a FP gauge to measure pressure.
    I want to say someone used to make an idle air adapter/adjuster for the 5.0 as well. I don't recall who, but someone made a plate that would go between the IAC and allow more air to flow? Something like that...As you said, it's been a while.
    Being that old, I've seen the throttle body shaft leak around the bushings. I've got a few 85/88/89 year 2.3T Fords, this is a big problem with them as well. See what happens if you spray some carb cleaner on the ends of the shaft with the car running, does the idle smooth out? If you can get to that before it dies.
    Aug 2010
    No Spin Zone
    2,912
    Shit, Dan posted the idle thingy from LMR...
    I have the FP rail adapter, but Exotic in Farmington has them also.
    Club Member black88coupe's Avatar
    YES my shit is slow and NO you can't drive it!
    6,886
    I had one of these laying around for years. Damned if I know where it is now. [QUOTEhttps://lmr.com/item/LRS-9939A/1986-...SABEgLOGfD_BwE[/QUOTE]
    Did the wizard ever get back to you about that brain?????
    I dont feel tardy
    9,985
    On a completely stock car. I can’t see where that would be needed. I sprayed all over the Intake..... I’ll focus on the TB tonight. It will start and run and drive. Just every now and then idle will drop to 500 rpm and sometimes die
  9. #19
    is it losing a crank signal?
  10. #20
    Club Member nitrousrick's Avatar
    Northside
    5,136
    If you haven’t yet I’d also pull the tb off and clean it.(if the fp checks out)
    84 Mustang Coupe
