I thought I had an ignition system issue on my car, but it turned out to be much more than that. I was trying to get my timing set and the car just would not stay running. I noticed the secondary’s weren’t squirting at all. Even pushing on the pump arm they were not working.
Quick fuel system overview. The car has a Magnafuel QuickStar 275 pump that recirculates to the cell, -8 line from the pump to the regulator block and two lines to each side of the carb. The second regulator has the nitrous system.
So after seeing the secondary were not working, I decided to pull the carb (AED Systems custom 820cfm) to give it a quick cleaning. When I took my fuel lines off I found this long black string of crud behind the fitting going into the rear bowl. The front had a small piece, but not as bad as the rear.
I tore down the carb and this is what I found;
D70BBDB1-7392-4FBF-9D36-417E16118608.jpeg853978F3-B776-471E-9CAE-0DEB20F17B96.jpeg08D0E077-9C6E-451D-ABB7-EC6DE6F6ED46.jpeg
WTF!!
The cell is clean, so breakdown of fuel cell foam is occurring, plus the pump recirculating would have filled the cell with shit if it were the pump. I’ve been running 110 unleaded rec fuel in it for the last few years, but I think it may have eaten my fuel lines from the inside out.
There looks to be a waterline on my metering blocks too? Any thoughts?
