Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Garage insulation - opinions needed
    Club Member 4Gas$'s Avatar
    Milan
    10,703
    Arrow
    I've owned several buildings. The one I now have at my home property is a
    stand alone 30'x40'. It has Fiberglass batts in the walls, foam & foil panels
    for ceiling. I also have full drywall on all sides.
    It is more than sufficient. I simply can't see spending that extra $3,500 on
    more insulating. I would think that money would be much better served
    somewhere else.
    Club Member derbydad276's Avatar
    part time Yooper
    5,098
    my 2 cents worth.... if your building from the ground up put radiant heat in the garage floor
    https://www.youtube.com/watch?v=uVkSKh2gefA
    Forum Member soap's Avatar
    Feb 2004
    In the garage
    6,243
    When I built my shop I did all spray foam in the walls and batts with blown in the ceiling (R-48) equivalent. All 3 garage doors are 2" thick insulated as well. It was the best money I ever spent. I leave the thermostat on 50* all winter and turn it up when I'm out there working. I have a radiant tube for heat, costs me $25/mo.
    The biggest advantage of spray foam is that it creates a complete barrier......you get zero air leaks. Batting or blown in will always have air leaks around outlets, against studs, corners etc.
    --Joe
    7,215
    Quote Originally Posted by soap View Post
    --Joe
    That is the best part about the foam. You can seal all of the outlets and suspect problem areas with caulk/spray foam etc and save a ton of cash. Your heating bill is pretty impressively low though.
    Jan 2010
    735
    Thanks guys - really good ideas. I'll ask about a thin layer of foam just to act as a vapor barrier.
    For the garage, walls will be R-19 batts, with insulated doors. I am thinking I'll end up with the R-30 batts in the garage ceiling (workshop floor) due to the cost, but will ask about foaming as a vapor barrier. The entire garage - ceiling and all - will be drywalled.
    Workshop (2nd story), I will figure out...at this point, it's going to be studs. I'll do blown-in in the attic space there eventually, and I am undecided as to what I'll do on the walls. I plan on installing a DIY (MrCool) mini-split up there. I didn't even think of a vapor barrier - just reached out to the builder to see what his plan is for that. Makes sense that I need something.
    Jan 2010
    735
    I'll look into the radiant as well - I think that'll throw us way over budget. We're going a bit out of control, so I need to reign it back in.
    Forum Member slow96hater's Avatar
    Mar 2008
    romulus, mi
    642
    One thing not to forget about though, especially in the winter time with a garage that has constant cars covered in snow and wet coming in for the night, you can seal a building too tight too. I'd vapor barrier just the ceiling between the garage and work shop area, and use normal fiberglass with paper backing in the walls, it'll allow the building to breathe and dry out, instead of holding all that moisture and humidity. It'll still hold plenty of heat that way.
    Club Member JoeliusZ28's Avatar
    Jul 2008
    Utica MI
    1,463
    In my eyes the only downside of foam is if you have to do any electrical or plumbing work later, but chances are you could add/route whatever you needed in the walls instead. The vapor barrier seems like a good reason to spend the $$$ in this case. Also, let me know how the mini-split setup turns out, i want to put one in my 2 car garage myself.
    -Joel
    95 Z28 6 Speed 373rwhp
    84 K10 4 Speed bitchin 305
    02 Z71
  9. #19
    Club Member kammi10's Avatar
    May 2006
    grand rapids, MI
    2,672
    when i just built my house i had them not insulate the garage and i'd do it myself. Bad choice. totally wish i would have just had them do it as i already had them do all the electrical and everything in it except the heating system. i did ti with fiberglass and they would have spray foamed it. for roughly 1.5 times the amount. but it would have been well worth it to me. the foam is way better.
