Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Fresh motor
  1. #11
    Forum Member gub's Avatar
    Nov 2008
    Clinton Twp
    1,082
    I just did a chassis
  2. #12
    Club Member nitrousrick's Avatar
    Mar 2004
    Northside
    5,136
    Auto or manual? Honestly those numbers don’t seem too far off to me.(torque seems a bit low.). Did Lidio also tune it?
    Years ago my 410w put down 43x or something along those lines on Lidios dyno. I was never impressed with the number but the car outran plenty of cars boasting bigger numbers.
    84 Mustang Coupe
  3. #13
    Club Member Beigg's Avatar
    Feb 2009
    I am here >x<
    5,376
    Quote Originally Posted by gub View Post
    Has 1 3/4 longtubes. The hp has a steady incline correctly but the torque is flat the whole way. Only did 338lb ft peak. But it was 300-338lb ft from 3200-6500
    Picture of the plugs? How fast is the coolant reaching op temp?
  4. #14
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    That seems like a 500 horse combo to me not a 600 horse combo. 550 horsepower would probably need 12 to 1 compression and a bit more camshaft which means a bit more RPM..
    600+ hp would probably need 15 to 1 compression and 8500 RPM. my 396 small block head 230cc heads more camshaft and 11 and a half to 1 compression and that made about 575hp. That was a hundred twenty eight mile an hour on motor at 3450 pounds with a Powerglide.
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
  5. #15
    Forum Member camaromann's Avatar
    Mar 2008
    Warren
    3,093
    My last sbc was stock block 355ci @11:1 and made 613 on engine dyno at about 7600rpm
  6. #16
    Oct 2003
    Metro Detroit, MI
    15,471
    If it was through a loose convertor then that would explain it all.
    2016 Camaro Convertible 2SS
  7. #17
    Nov 2008
    Clinton Twp
    1,082
    Quote Originally Posted by Beigg View Post
    Haven't had a chance to look at the plugs.
    The car is an auto and the coverter was locked for the dyno pulls
  8. #18
    Dearborn
    6,003
    Quote Originally Posted by camaromann View Post
    What kind of cam? Something around 265+ @ .050" right?
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
  9. #19
    Mar 2008
    Warren
    3,093
    I honestly dont remeber. I messed it up though when I ordered it becasue I thought I knew better lol. It wasnt huge. Around .650/.680 lift and I know advertised it was over 300 a bit. It was a solid roller. I had them put it on a 108 lobe, but it should have been on a 110 or 112. Would have made more power dammit. I had lot of little stuff done to the rotating assembly, and the cylinder heads were VERY good. I spent over a month coming up with ideas and what to do with the ports and chamber. Intake was a crappy team G single plane the was untouched except a port match.
  10. #20
    Club Member Anthony's Avatar
    Jan 2004
    I dont feel tardy
    9,985
    What fuel?
    Ida used 60lb injectors. But that’s me.
    Is it running out of fuel?
    Any data logs you can post?
    What efi? Who tuning it? Lidio?
