Results 1 to 3 of 3
Thread: 2015 F150 Coyote boost questions...
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    Default 2015 F150 Coyote boost questions...
    Anyone know how capable the fuel system is on this truck? How much power can it feed? Injectors, pump, lines, rails...which part is weakest? If the injectors can feed 400hp on E85, is it wrong to assume it can feed 500-550hp on gasoline?
    I'm thinking about putting a small turbo under the cab where the resonator is currently. It would be fed with the stock catted exhaust manifolds. Cheap ebay intercooler up front. This seems like it would work ok with minimal fabrication. 70-76mm compressor... We've all seen rear mount turbo setups work so why wouldn't this? Input welcome!!
    Forum Member BrainFearGone's Avatar
    Jun 2004
    1,657
    Take a look at on3. Pretty sure they just went 10s on a bone stock 5.0 with their kit. Not saying go with the kit but might give you some good info.
    Elected Club Official
    Sep 1999
    "The Place to Be"
    35,656
    I'll tell Yonson to check this thread
