Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: hey guys got a 2016 jeep with a voltage problem....
    Club Member ASRoff's Avatar
    Apr 2004
    All spooled up and no place to go.
    6,068
    Default hey guys got a 2016 jeep with a voltage problem....
    Like the title says... this is strange.. lights flicker and voltage drops from 14.5V to 11v and back..... every 10...20 seconds... replaced alternator and still have the issue... does this thing have a external voltage regulator?
    motown muscle southern chapter "we find rust free material for the michigan masses"
    08 Mustang GT broke but beautiful
    99 saturn SL1 with the air box removed for POWER!!!!
    Ford Chrysler or GM it doesent matter to me as long as its domestic.
    A mysterious figure named Darko DarkoStoj's Avatar
    Mar 2005
    work
    9,114
    Quote Originally Posted by ASRoff View Post
    I believe the votage is regulated by the PCM
    Apr 2004
    6,068
    Quote Originally Posted by DarkoStoj View Post
    yeah darko… that is what im afraid of....
    Club Member Beigg's Avatar
    Feb 2009
    I am here >x<
    5,376
    The battery post connection tends to be a problem. Replacing the cable and connector ends usually fixes it.
    Apr 2004
    6,068
    Quote Originally Posted by Beigg View Post
    Beigg…. this this seems like its cycling.... like a voltage regulator.. would the connections do something like that?
    Forum Member slow96hater's Avatar
    Mar 2008
    romulus, mi
    642
    Don't buy Chrysler. Lmao! I'd try the battery post too. Chryslers are real particular with their electrical systems. Once worked on a caravan that had corroded terminals that was making the vehicle operate in limp mode, and stayed in second gear. Never woulda figured it out if my buddy wasn't a electrician for Chrysler.
    Club Member 1BADAIR's Avatar
    cardboard box
    28,354
    What engine. Is it a startstop3.6?
    cardboard box
    28,354
    Could be the battery,IBS or pcm. The Reg is in the pcm but a lot of data comes from the IBS. The IBS does take some time to relearn after the batt has been disconnected also
    Feb 2009
    I am here >x<
    5,376
    Yes if it's setup similar to a 2014 jeep patriot. The patriot exhibited similar characteristics & replacing the battery pos & neg cables & connector ends with new cables containing the lugs resolved the issue. Cutting away the pos connector end from the cable revealed the corrosion I expected to see.
    cardboard box
    28,354
    The battery/batteries are under the passenger seat so those terminals probably aren’t an issue . If it is a ESS 3.6 I would make sure the aux battery is good
