Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: G8 gt dod
    Club Member svtserpent's Avatar
    Sep 2008
    1,884
    Default G8 gt dod
    I think I may have the dreaded DOD noise, it doesn't sound like a lifter more like a softer clicking coming from the back of the left head. That being said, how bad of a job is the dod delete? I read you need to pull the heads. Or is there a sponsor on the boards that can do the job.
    Club Member littlemissGTO's Avatar
    Aug 2009
    Southfield, MI
    1,202
    You do need to remove the heads to get to the lifters.
    Club Member 99TransAmWs6's Avatar
    Roseville/Macomb, MI
    6,522
    It is a bit of a job. I just did this for my brothers G8 last year. Full top end comes off. Intake, heads, manifolds ect. BTR racing sells a kit usually that has what you need lifters, valley cover,head gaskets, ect.
    If youre doing it, its a great time to do 3 bolt cam swap while youre at it. Id treat it more just like a cam swap deal. Do pushrods, timing chain, trunion upgrade, new head bolts/studs.
    Youre most likely going to be in around $1800-$2000 i think in just labor(im ball parking as i dont recall what my brother was quoted before i did it for him). I had gotten quotes just dont remember.
    -Cory
    *MPH Whats Your Limit?*
    1999 Turbo Trans Am WS6
    Rear mount retired
    2015 Silverado 2500HD LTZ Z71 6.6 Diesel
    2010 Corvette Z06
    Racing to some people equals 10% racing....90% trash talking.
    Club Member Beigg's Avatar
    Feb 2009
    I am here >x<
    5,376
    If the camshaft is ok, it saves some work & cost if all you're after is stock power.
    Otherwise, if the camshaft needs to be replaced, I recommend picking up a long block reusing your bolt-ons to drop in... or short block & your heads+..
    Sep 2008
    1,884
    So yeah, I pulled it in and listened to it a little closer, Im pretty sure its a collapsed lifter DOD thing..... Im thinking/hope the cam is okay since it just started.
    Time to start driving cobra as a DD...
    6,522
    The camshaft should be fine, but its a good time to upgrade seeing your in there. I personally would just fix what you have. Im not sure id go the longblock idea as above, you might just end up in the same situation youre in now.
    Parts arent super expensive, its just labor intensive.
    -Cory
    Rear mount retired
    2010 Corvette Z06
    Sep 2008
    1,884
    I've done cam swaps & had heads off cars -BUT-I have zero LS experience, mostly old Pontiac 400/350 engines. This is all new to me.
    Club Member 85notch's Avatar
    Jun 2005
    2,726
    If you are looking for a shop contact JP at JZ auto
    R and D racing.
    Feb 2009
    I am here >x<
    5,376
    If you're doing the cam, you minds well pull the motor & work on it. Long or short block, I would go with a rebuilt/reman/new. Had no intent to mean junkyard engine.
    Just doing the lifters, the heads come off, but doable with it still mounted in the car.
    6,522
    Quote Originally Posted by Beigg View Post
    Yea i knew what you meant. It can be done with it all in the car still though. I did the full DOD delete/cam swap with it all in the car. Ive done numerous LS swaps/cam deals yadda yadda.. It all in the car isnt bad with the correct tools.
    -Cory
    Rear mount retired
    2010 Corvette Z06
There are currently 2 users browsing this thread. (0 members and 2 guests)
