Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Open car trailers
  1. #11
    Club Member Anthony's Avatar
    Jan 2004
    I dont feel tardy
    9,985
    Quote Originally Posted by wrath View Post
    They used to offer a cash discount also, not sure if they still do. They will work with you on price depending on what "options" you want on it. They make the trailers right there so there is no middle man. So if you really want to buy two of them they might give you an even better deal.
    That trailer on FaceSpace is an angle iron trailer... going to tow like a wet noodle, especially with that long tongue. Would not be surprised if you don't block up the back of the trailer if you were to drive something heavy on it that it'd fold up.
    I doubt it would “fold up” with a 3000lb car on it.
    Tongue looks longer on the Jackson built trailer.
    Both are of the fame frame design
    C channel.
  2. #12
    Club Member wrath's Avatar
    Jun 2005
    Chelsea, MI
    932
    Quote Originally Posted by Anthony View Post
    C channel.
    Why the heck are you getting a 20' trailer to tow a small car on it? It's unwieldy. 20' car hauler is for crew cabs and Suburbans or making sure you only need one trailer for everything.
    Angle iron trailers are wet noodles going down the road. That's why most of the "landscape trailers" have a "crash rail" about 16" above the deck... it's not there for your convenience, it's to try to stiffen up the trailer.
    The tongue length matters more than most people think. The longer the tongue, the easier to put too much or too little tongue weight on the trailer. The longer the tongue without a deck the more it will flex. The longer the distance between the trailer axles and the coupler the more the frame of the trailer flexes.
    The trailers aren't even close to the same design.
    A good trailer at that size/capacity will have a piece of 5" channel for the whole frame. Cross-ties will be made of at least 2x3x3/16" angle, preferably 3" channel. The tongue would ideally be at least 4" channel that goes back to the front spring hanger. Sometimes people bend the same piece of 5" channel the frame is made out of and use that for the tongue, but that raises the coupler up high enough that you need to flip the ball mount upside down on a half ton truck. Also, once you bend the 5" channel you take some strength out of it.
    This is a very high quality trailer but it is expensive:
    https://www.pjtrailers.com/trailers/...l-buggy-hauler
  3. #13
    Club Member 1BADAIR's Avatar
    cardboard box
    28,355
    Have to watch. Pretty sure in Michigan they are required to have brakes on both axles now
  4. #14
    Club Member twotwoturbo's Avatar
    IN A VAN DOWN BY THE RIVER
    5,725
    Quote Originally Posted by chacho44 View Post
    Spend the money and get an aluminum trailer.
    I towed a featherlite car trailer...towed like dream I am all for aluminum trailers !
    1990 mustang GT 5.0 sold 3-11-04 MISSED
  5. #15
    Jan 2004
    I dont feel tardy
    9,985
    Quote Originally Posted by twotwoturbo View Post
    Too rich for my blood!
  6. #16
    Club Member kammi10's Avatar
    May 2006
    grand rapids, MI
    2,672
    my dad just got a brand new RnR aluminum 18 ft for i think just under 5k.
    if i was going to get one again it would be aluminum. its so much easier i can literally push it through the grass by myself.
  7. #17
    Jan 2004
    I dont feel tardy
    9,985
    Secondary purpose is to pull a car.
    Primary is to pull my Polaris ranger 10’ long and my zero turn up to St Helen.
    Mower is 6’
    18’s have a 16ish foot deck with 2’ dove
    Plenty of room on a 20’ and if I end up buying my son a ATV, I got room
    Then pull a car somewhere if needed
  8. #18
    Oct 2008
    at home with the family
    5,226
    I seen an aluminum double axle dove tail used for sale in green oak today but couldn’t stop, if that’s something you are interested in all get the number. Looked like an 18’ maybe.
  9. #19
    Jun 2005
    Chelsea, MI
    932
    Mower is 6’
    I would just find a cheap used landscape trailer then.
    I would not want to move a car with an angle iron trailer. They do bend and they do flop around. I know they bend because I've had people ask me to straighten their trailers. One was so mangled I bought it for scrap and used it for a bridge across the creek.
    I have a small utility trailer I bought off a guy for cheap (it's 5x10) because he bent it driving his Razor into the trailer without supporting the tail constantly. It popped a couple welds on the crash rail so it bent. I fixed it like I do with all the others and used an A-frame and a double-lined 12,000lb winch. It's still 1/2" drooping out the back.
    If you really want that angle iron trailer you can make it stronger by adding a rail of box tube up higher but that defeats the purpose of a flat bed trailer. Usually what I do is use a piece of box steel and then run 14 gauge sheet between the old deck and the crash rail. Stiffens the trailer immensely but still lets it twist enough not to pop welds.
  10. #20
    Jan 2004
    I dont feel tardy
    9,985
    https://detroit.craigslist.org/wyn/f...971762277.html
    4” C ok?
    Pros/cons of wood vs steel deck
