Im tired of paying insurance on it as a back up car. I am giving a harsh verbal detailed description and if you have any questions, when you come to check it out THEN your questions will be answered.
I trust the pos, there’s everything wrong with it!
It runs and drives, I have no problem jumping in it and drive an hour on road or freeway, probably a bad front strut, has a little oil leak here and there, has manual steering due to blown seal on rack, dings dents and rust. Crack along lower windshield, driver window not working( assume the relay) rear wheel has a little lean to it( has for years). 1 factory speaker works!
Driver side mirror housing is externally screwed back on and glass mirror is siliconed in place, pass mirror housing is also screwed! Etc... there’s more wrong I’m sure!!
Again it only seats 2.
2 15” Soundqubed hds3.1 subs in a HUGE b pillar 6th order band pass tuned at 25hz/50hz. She has shocked a lot of people, most can’t handle it when set up @ .5 ohm. It’s not competition loud but gets down.
Wolfram 2400 amp @ 2 ohm only around 1k watts, 1 group 31 marine/deep cycle behind seat.
(I had 6 group 31 deep cycle batteries with amp @.5 ohm , a little over 2k on the stock alternator for years, externally charging daily to help charging due to stock alt)
Motown folks get a deal, possible trades are
Handy man/ carpenter/electrician , automatic trans for a 2.3 Lima a4ld, c-4 or any other auto 2.3 trans, gun, hugs may be considered depending if there from the heart, idk try me.
Pm me questions or number.
