Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Anybody know what would cause one spark plug to oil foul?
    A mysterious figure named Darko DarkoStoj's Avatar
    Mar 2005
    work
    9,114
    Default Anybody know what would cause one spark plug to oil foul?
    Having an issue on the current engine in the Rolls Royce racecar that has the Viper V10 engine in it.
    #10 spark plug is oil fouling. Changed the valve seals and it's still happening. Compression test is fine. Only thing I can think of is a cracked piston or oil ring issue?
    I've never had this happen before and am a bit stumped.
    Ideas?
    Forum Member
    May 2008
    Rochester Hills
    2,464
    Cylinder walls may be badly scored.
    Forum Member wickettoby1's Avatar
    Oct 2013
    SE Michigan
    209
    How about a worn out valve guide?
    Have you done a leak down test on that cylinder?
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    How fast does it do it? Is it burning oil?
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
    Mar 2005
    work
    9,114
    Quote Originally Posted by wickettoby1 View Post
    Did a compression, but not a leak down. Do you guys think a leak down will find the problem?
    When we were at the track, it would oil foul a fresh plug in about 10-15 minutes of track time.
    Oct 2013
    SE Michigan
    209
    If you have access to a leak down tester I believe it would be a worthwhile test.
    Is it possible that the viper engine has a design flaw that effects just the #10 cylinder? Something stupid like a vaccum line from the PCV or ????
    Full disclosure I know 0 about viper V10's just thinking outside the box as you've covered most of the bases.
    Club Member 1BADAIR's Avatar
    cardboard box
    28,355
    have a catch can installed for the CCV/PCV? track have big left turns?
    Oct 2003
    Metro Detroit, MI
    15,478
    I had a 1976 Tran Am that had the same problem. It was just the cylinder wall. I am not sure how to detect it without just looking in the cylinder.
    2016 Camaro Convertible 2SS
    Club Member Duke's Avatar
    Southgate
    3,315
    My Camaro's engine had this issue. Turned out to be a cracked piston.
    I like pie.
    Club Member twotwoturbo's Avatar
    IN A VAN DOWN BY THE RIVER
    5,726
    Quote Originally Posted by DarkoStoj View Post
    Ideas?
    have you tried one of them non foulers they make in the help section to see how it does....
    1990 mustang GT 5.0 sold 3-11-04 MISSED
