Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 62
Thread: '55 Chevy Bel Air Build Thread
  1. #51
    7,230
    You can never get that patina back once its sanded away. Id keep the body as-is, make the car as driveable as possible and maybe do the body down the road if you change your mind.
  2. #52
    Elected Club Official jsxtreme's Avatar
    Bestside
    22,278
    The passenger side is perfect, I'm leaving it. The issue is the driver side. There's all this wonderful patina and then the pinkish primer over it. So that's what Im trying to get off.
    But, yeah. I agree.
  3. #53
    7,230
    It looks like it might be faded red oxide primer. Maybe try wiping it off with laquer thinner in a test spot.
  4. #54
    Bestside
    22,278
    I'll try that, thanks. The problem is the paint under it is checked and falling off. Im afraid thats what's going to come with it. It is what it is.
    Ive found some really great videos on how to accelerate patina. Good chance I strip it, paint it, and then re-patina is this winter.
  5. #55
    Bestside
    22,278
    Trying to make a complete list of new parts I have in it:
    '55 Chevy disc brake conversion Kit
    New Aluminum Radiator
    New Gas Tank
    New Gas Tank Straps
    Intake Gaskets
    Holley Renew kit for the carb
    Moroso Advance Curve Kit
    Starter
    Water pump
    Fuel filler neck
    Battery
    Rear brake union
    Rear brake drums kit, pads, brake cylinders
    Package shelf tray
    Hoses
    Belt
    Floor Pans
    Sending unit
    Hood latch repair kit
    Factory Battery Hold Down
    Rear leaf spring bushings
    2" drop coil springs
    Wheels / tires
  6. #56
    Bestside
    22,278
  7. #57
    Bestside
    22,278
  8. #58
    Bestside
    22,278
    Next on the list:
    - Drivability - Needs some tuning
    - Electric Choke replacement
    - Water temp gauge
    - Lower 2" and replace bushings
    - New Fuel pump
    - Wiring clean up / replacement
    And then, body work.
  9. #59
    Bestside
    22,278
  10. #60
    Bestside
    22,278
    Ordered a glove box lock retainer, push button lock for the glove box, trunk lock kit, amber front parking lamp lenses , LED bulbs for the tail lights and front parking lights.
    Working on sorting out some low RPM drivability stuff (carb issues mostly) and cleaning up the loose ends on the wiring. (there are many, and I hate wiring so a buddy is helping) I don't know if I'll scrap all the wiring and start over during the winter, it seems like if we clean it up and repair the bad stuff it should be solid. So thats the plan for now.
