Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Laser pulley alignment
    Forum Member ultradriver10000's Avatar
    Jun 2015
    Clarkston
    904
    Default Laser pulley alignment
    Does anyone have a laser pulley alignment tool I can barrow or know of a shop that has one that can check my blower alignment on the quick?
    I have an F1-X blower with an 8 rib set up, but I keep snapping the damn belt. I have two red bypass valves and a huge BOV, not sure what else it could be. Just want to make sure the pulleys line up before I order 10 rib pulleys for her.
    Forum Member wickettoby1's Avatar
    Oct 2013
    SE Michigan
    209
    Is it breaking the belt under load or when you lift the throttle?
    Jun 2015
    Clarkston
    904
    Quote Originally Posted by wickettoby1 View Post
    Normally when I lift.
    Does anyone know if it is better to have a slightly longer or shorter belt? I have an adjustable spring loaded tensioner, so I can run belts +/- an inch or so. I've been using the smallest belt that I can, but maybe a slightly longer belt will let it stretch more?
    I ordered a 10 rib pulley and a gates RPM belt, so we'll see what that does. I have been on an 8 rib and normally using the Gates Green belts.
    Oct 2013
    SE Michigan
    209
    I had the same issue as you on my Foxbody. When I would lift off the throttle the belt would eject itself off of the engine or break. In my case it was the fact that someone previous to me had removed the Procharger designed/supplied belt tensioner and installed their own design.
    I would check your tensioner to make sure that its adjusted properly and pretensioned.
    Oct 2013
    SE Michigan
    209
    I thought alignment was my issue also so a buddy made me up a jig with a dial indicator on it to check the alignment from pulley to pulley. All along it was the tensioner.
    Oct 2003
    Metro Detroit, MI
    15,471
    There is a place in Indiana that I heard did good work with pulley alignment. They did someones car on here I can't remember whose though - maybe George's? I want to say Dynotech maybe?
    2016 Camaro Convertible 2SS
    Jun 2015
    Clarkston
    904
    Thanks for the advise, the pulleys look straight with a straight edge and the belts don't show side wear, so the tensioner could be a real possible issue.
    Quote Originally Posted by WhiteHawk View Post
    Thanks I'll check it out.
    Club Member Torxila's Avatar
    Farmington Hills
    1,270
    I have a Gates 91006 tool if you want to borrow it. I'm in Farmington Hills 48331-1272
    https://www.amazon.com/Gates-91006-S.../dp/B000WYFI1A
    Text me: two 4 eight three one eight two 8 seven 8
    George
    torxila@gmail.com
    "If it Flys, Floats or F**ks...RENT IT'.
    "I own Firearms and a Backhoe"
    "Smart as a horse, hung like Einstein"
    Club Member 1BADAIR's Avatar
    cardboard box
    28,351
    Sure both reds are working?
    Jun 2015
    Clarkston
    904
    Quote Originally Posted by Torxila View Post
    George
    torxila@gmail.com
    Texted
    Quote Originally Posted by 1BADAIR View Post
    Humm I think so, I'm not even sure how to check that any tips?
