2003 Mustang Cobra, 56k miles, solid axle car, upr adj upper control arms, mega bite jr lower, 390 gears, ta cover, Eaton true trac, 31 spline moser axles, tokico adj shocks/struts, frpp rear springs, frt coilovers 14/200, PSR tubular k member, mm caster plates, mm subframe connectors, battle boxes, jlt cai, sct meter, Stegi ported blower that’s polished, egr delete, 2.76 billetflow pulleys, 2lb lower, boost a pump, bigger radiator/heat exchanger, polished tanks, 26 spline input shaft, spec stage 3 clutch, hood struts, hid headlights, svt door panels, speed of sound gauge pod, raptor shift light, extended studs, hood struts, aftermarket stereo, shifter, catted x pipe, slp cat back. Car will come with the white 18” roh wheels and not the BBS wheels. $30k/obo. Arizona car it’s whole life
