What is the maximum downward pinion angle I can use?
depends on suspension and use.
1930 model A, 350/350.
The rear is coilover with hairpin control arms. Assume the trans is installed level.
race car, or street car?
street car is ok to have 1-2 degrees down, but make sure that both ujoints have a couple of degrees on them(not strait), or they will not lubricate properly
Depends on transmission angle also!
REAL RACE CARS HAVE 3 PEDALS!!
My understanding of pinion angle is the it should be the opposite of the transmission angle. The line continuing from each should be parallel. So if the trans is +2 degrees, the rear should be -2 degrees if the installed height in the vehicle of both parts are the same.
The question is what is the maximum angle I can point the pinion downward?
I missed the trans was level, -2 to -4 will work without any problems.
