Just wonder at what speed or whatever that it is either good practice or totally necessary to weld the axle tubes on a ford 8.8" rear end.
I would assume especially if you use an anti-roll bar that welds to the tubes that it would be important to weld the center section.
I want to get this done, but my main issue is that my rear end is all together and setup which means that I'd have to tear it all apart.
Would the tolerances change so I'd need someone how really knows what's up to set it all up again or could I put it back together myself with the correct bushings/shims/spacers in place?
Any help would be much appreciated.
