12.2 inch 4 piston kit PRE140 6163 $850.00
Click to enlarge
12.2 inch 4 piston kit for the Prelude includes the 2 piece slotted & drilled rotors, small Dynalite 4 piston calipers, pads, brake lines and mounting hardware.
Price: $789.95Now, you have info on both kits, which would you rather prefer to run? Anyone with experience with the two brands?
- Force 10 SuperTwin; 2-Piston Disc Brake Kit; Front; Incl. Calipers/12 in. Rtrs/Prfm Pads/Mounting Brackets/Flex Hoses/Necessary Hardware; Aluminum Calipers;
- Increases Braking Power
- Multi Piston Design Decreases Pad Deflection
- Stainless Steel Bleeder Screws For Durability
- Strong Yet Light Weight Forged Aluminum Const.
- Uses Off Shelf Pads For Easy Replacement
