What exactly do you want a price for? tubs and frame notch only, or include back seat delete metal work, is it stock suspension? if so would you like to stay that way or go ladder bar? does it have a cage and frame connectors? heres a notch i just finished:
mini tub,ladder bar, coilovers, seat mounts, thru the floor connectors,misc. other things http://good-times.webshots.com/album/567621294hFJxWz
let me know and i'll give you a ball park and PM a phone number so we can nail down the specifics
Thanks
When I originally asked the question it was more me wondering if it would be in the $500-1000 range, the $1000-2000 range, or the $2000-5000 range, etc. etc., hence asking for a ballpark. I can do the former, but I don't want to call and tirekick a bunch of shops if it's clearly out of my price range, which the latter 2 categories realistically are.
Most of the time just the parts for the mini tub will be around a grand. Coil overs, relocating the brackets, narrowing the rear end, and the tubs. all this stuff adds up.... Most people I know can't work for free so they have to charge some labor. But if there is a different way of doing it like the old Mopars where they have a city block under the back end than I would be thinking too much....
Jeremy
FLOORMAT RACING
I was just looking for a quote on the actual mini-tubbing, not narrowing the rear end, coilovers, etc.
I literally just want the factory tubs cut out, and the new tubs welded in. Maybe bracket relocations if it is necessary for correct suspension geometry. Naturally all that other stuff would be separate and cost extra.
Oh man you're talking about a lot of other stuff on top of the mini-tub. All a mini-tub is to me is making the car fit a taller/wider tire. That's the tubs themselves (cheap if steel) and a little bit of cutting and welding. Adding all that other stuff isn't cheap, that's for sure. But I don't think it's necessary in all circumstances.
'00 Camaro
PBMF > *
When you do a mustang you have to cut the spring perch. Not too sure on the F-Body...
Jeremy
FLOORMAT RACING
