Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: 81 fairmont wheel hop...
    Club Member
    Feb 2009
    some where
    483
    Default 81 fairmont wheel hop...
    the fairmont my brother in law has is wheel hopping like a kid on a pogo stick. its so bad that he keeps snaping shocks.... after installing some lakewood drag shocks the hop wasnt as bad but nothing to brag about. and we noticed that the shocks where dented on the back side by the axle housing. so i have a feeling that he is getting some serious flex back there, throwing the pinion angle all to hell which maybe the source of the problem??? the car is by no means a high hp beast. just a fi 302/t5 with some bolt-ons. any thoughts?
    '86 notch--> fired up and ready to go
    Club Member John Boschma's Avatar
    Jan 2009
    SOUTH BELOIT ILLINOIS
    225
    the bushings in your upper and lower control are junk. you need to put some aftermarket control arms in and that will eliminate your wheel hop tremendously if not all of it.if it's not a drag car and see's mostly street duty i would just get a set of non adjustable control arms that have urethane bushings. you can buy a complete set off ebay for $150.
    the wheel hop is all caused from the soft stock rubber bishings,and i'm sure thier worn pretty bad. and be sure to replace the upper bushing in the axles tabs as well.
    Club Member
    Feb 2009
    some where
    483
    ya i was thinking that was the cause but im not sure if just uca/lca's will help. i think we are gonna take the adj uppers and lowers off of my notch just to see how much (if any) improvement there is before he buys some.
    Forum Member nuttsgt's Avatar
    Oct 2005
    sulphur springs, ohio
    2,586
    when you change the bushings in the axle tabs, it's alot easier if you take a torch and burn them out. . . . but please use some common sense when burning them out. . . . like having the rear out of the car.
    Club Member black_cobra_95's Avatar
    Jul 2008
    detroit
    700
    You could try installing some quad shocks
    Jan 2009
    225
    Quote Originally Posted by black_cobra_95 View Post
    Club Sponsor
    Apr 2004
    SE michigan
    2,577
    Quote Originally Posted by John Boschma View Post
    Welcome to mowtown muscle John!
    "You didn't Build it" LMFAO isn't that what Oboma said too?
    Jan 2009
    225
    thanks Dave.
    Jul 2008
    detroit
    700
    Talking Not as Gay as.....
    The pink in that avatar of yours is!!!
    A mysterious figure named Darko DarkoStoj's Avatar
    Mar 2005
    work
    9,114
    here you go, this will fix all problems for not tooo $$$$
    http://www.hotrodsandhemis.com/Traction.html
