Results 1 to 10 of 12
Thread: T-5 Trans build up for 350 V8
    May 2007
    129
    Default T-5 Trans build up for 350 V8
    Im looking to replace my Saginaw 3-speed with possibly a T-5 to mate to a 350 in my 65 C-10 as its supposed to be the easiest/cheapest trans with OD. From what I am reading they aren't the strong to go with a mild 350, does anyone local build these up to take a 350 in a truck by chance? I don't want to go 700R4 yet but really need OD since the truck came with 4.10 rear. Would love a TKO but $$$. Any help appreciated.
    Liberty gears.
    Forum Member Detroit Gearbox's Avatar
    Jan 2007
    Warren Michigan
    4,912
    Popular swap is a getrag 5 speed for C-10's out of like 1500 pick up 2wl from the 90's ... have to use a curving shifter handle to clear the bench seat... you can identify them by the bell housing, its part of the trans.... seen lots of info on line from other C-10 owners.... I see this trans from time to time online.. they sell for 500 or less... I would not advise using the T-5 with a V-8... maybe a 6cly.
    May 2007
    129
    Ill see what I can find from a 2 wd Silverado, thanks. Ive read the AX15 from jeep is a viable swap as well.
    Club Member derbydad276's Avatar
    part time Yooper
    5,097
    here are a couple options .... not cheap but... if you want to keep the column shift .....
    https://www.ebay.com/itm/SAGINAW-3-S...oAAOSwFe5Xxf7a
    https://www.ebay.com/itm/SAGINAW-4-S...4AAOSw8w1X-9st
    Driven Crazy
    May 2007
    129
    The shifter is on the floor now and Id like to keep it there, since the clutch is fried I thought I would upgrade the Saginaw 3 speed since its coming out anyway, it is a snychroless 1st gear trans. its not a race truck, wont be doing any 1st gear dumps, well not too many. I know advance adapters makes a AX15 adapter to a SBC and I am going to see how viable that is. I don't understand that R-10 governor/overdrive setup for the 3 speed.
    Any advice on the NV3500, seems like there are plenty of those that could be bolted up to a SBC?
    Quote Originally Posted by derbydad276 View Post
    Oct 2006
    At the lake
    699
    If you're going to pull the trans you might as well pull the motor, then complete swap to a FI LS motor with a T56. Don't you have a guy to do this for you anyway?
    Might as well do it now since you're going to need a new driveshaft anyway. While your at it I hope you're going to put it on air too.
    Club Member daveg's Avatar
    Hell, Mi
    5,358
    Correct me if I am wrong, but don't all those transmissions you are trying to swap have a hydraulic clutch setup?
    Quote Originally Posted by sidewayscoupe View Post
    Will someone please lock this fucking thread.
    part time Yooper
    5,097
    Quote Originally Posted by daveg View Post
    easy peasy .l..
    took me 3 seconds to find it on the web
    http://transmission.moderndriveline....Kit-26p911.htm
    Driven Crazy
    Club Member DRAG-ULA's Avatar
    Apr 2009
    Smokin' cigarettes and watchin' Captain Kangaroo
    4,047
    Oh man how cool is that?!? I love the 3 on the tree in my 51, but hate the trans.
    I used to be 'with it'. Then they changed what 'it' was. Now what I'm 'with' isn't 'it', and what's 'it' seems weird and scary to me.......
    1948 Dodge B1 pickup
