Results 1 to 6 of 6
Thread: 2017 Equinox
    Feb 2007
    4,866
    Default 2017 Equinox
    I have a 2017 Equinox, when I went to add oil to it there was a light tan ring aound the bottom of the oil cap. The same color oil also poured out of the hose that connects to the side of the plastic engine cover.
    The spark plugs look good for 130,000 miles, dry, not burning oil.
    Is this a faulty PCV valve causing this?
    If so, what engineer at GM thought it was good to have to remove the intake to replace the PCV valve?
    Forum Member transamtom's Avatar
    May 2010
    Niagara Falls
    424
    Thats moisture/condensation in the crankcase.
    Do you take a lot of short trips?
    7,215
    Quote Originally Posted by mrvids View Post
    I have a coworker that had a Cruze with PCV issues. Something about a ripped diaphragm and it not being serviceable if I remember correctly. I wonder if it is the same/ same style system.
    Forum Member BrainFearGone's Avatar
    Jun 2004
    1,657
    Ya pcv is built into the cam cover. I had to replace 4 on my Cruze.
    Club Member 1fstfox's Avatar
    Dec 2006
    Napoleon, OH
    2,177
    There's a guy making a problem solver kit for the Cruze. Not sure if it's the same for the Equinox but it'd be worth looking into. The "kit" basically just replaces the stock hoses and uses an inline check valve.
    -Ryan-
    91 Slow'noma - 14 Cruze Diesel - 16 Ram 1500 Limited
    16 KTM 1290 SuperDuke R - 18 GasGas TXT300GP
    28,355
    Quote Originally Posted by BrainFearGone View Post
    Just did my nephews 1.4 cruize. The intake manifold causes the issue. The valve breaks in the intake .
