Blower Install, hood won't shut???
I have a 86 GT with stock hood, I added a used Novi 1000 blower kit for a Fox Body. It bolted up fine but now my hood won't shut. A cowl hood won't matter either because the hood is hitting the oil feed line on top the blower housing and the inlet pipe to the throttle body which is to far over to fall under the cowl portion. We aren't sure why or what's different?
I even added a full Team Z front end kit with new K-Member for which sometimes lowers the engine. Guy that did my install stated maybe look at adding solid engine mounts which might help but not sure that's the cure. Any thoughts on what's causing this or what to do to fix?
