Shit, its all coming back to me. I remember reading about those powerheads back in like 96 or 97. I'm haviong flashbacks!
Here are the specs on the cam and springs. Would need to know the install height to rule out coil bind.
The crower stage 3 camshaft Part#15513 has an advertised lift of .512/.531
Comp Cams #249-987-16
Dual Valve Springs
Outer inside diameter: 1.070"
Inner inside diameter: .697"
Seat load: 121lbs @1.800''
Open load: 343lbs @1.200''
Coil bind: 1.150''
Rate: 370lbs/in
With damper
16 per package
Strange they don't show a E7 head with 2.02 valves.
Engine:
91 Roller Block, Stock Bore
Forged Pistons 10:1 These are suppose to be stock, but Ford never had a 10:1 piston in a roller motor. Where the heads milled? How do you know the compression?
Reconditioned, Polished, stock rods w/ARP bolts
Micropolished Stock Crankshaft w/ modified oil passages.
Clevite "H" Bearings (Main and Rod)
Melling Oil Pump w/ ARP shaft
SFI Balancer and Flexplate
Crower stage 3 Roller Cam
Ford Racing Roller Lifters
ARP Head Studs
All Fel Pro Gaskets (Head, Intake, 1 piece oil pan, front cover and water pump set, front and rear seals)
Comp Cams Hardened Pushrods
Cloyes Double Roller Timing set w/ steel gears
Edelbrock Water Pump
CNC Ported Heads 2.02 1.60 Stainless vavles (New seals, valves, Comp 987 Dual Springs, Comp Retainers and locks, machined for screw in studs and guide plates)Something isn't right here.
Harland Sharp Rocker Arms (1.6)
Black Ford Racing Valve Covers w/ K&N Breathers
All ARP Fastners (Intake, Oil Pan, Front Cover, Valve Cover Studs)
Victor Jr Intake
NEW Proform 750 Carb w/billet base plate and metering blocks
If I had money like Henry Ford, Lord Id have me a woman on every road, But someday baby,You aint worry my life anymore
People say he's a nice, but they also said that about Ted Bundy
<----Jesus loves you, but I think you're a cunt
I think a 58cc head will yeild about 10:1 with a stock pistons and gasket. Not 100% posistive.
The car has a digital 6 ignition box, do these not come with a soft touch rev limiter?
Just looked at the picture of the valves in the first post. If they had 2.02/1.60 valves they would almost be touching.
84 Mustang Coupe
We have built literally thousands of CNC ported factory cast iron heads for over 10 years. POWERHEADS have been featured in many high performance magazine articles, and for good reason . . . THEY MAKE HORSEPOWER. Do not under estimate a good set of ported factory castings. POWERHEADS provide exceptional low end throttle response and great mid/top end power as well. If you want the original Ford castings and demand the finest workmanship, POWERHEADS will build you the best performing heads. . .
*Customer to provide heads or a $200 core charge will be applied*
ALL E7 5.0 HEADS INCLUDE COMPETITON CNC PORTING, SOLID BRONZE GUIDES, 5 ANGLE MACHINED SEATS, 1.90x 1.60 FORGED SS SWIRL POLISHED VALVES, .530 LIFT SINGLE VALVE SPRINGS WITH CM RETAINERS AND VITON OIL SEALS. PROFESSIONALLY ASSEMBLED AND VACUUM TESTED TO ENSURE VALVE SEAT INTEGRITY.
570 LIFT DUAL SPRINGS = $65 10 degree TITANIUM RETAINERS = $90
CUSTOM VALVE SPRINGS = CALL WIRE LOCK RECEIVER GROOVES = $120
SCREW-IN STUDS WITH GUIDE PLATES = $150
Looks like they have 1.90 x 1.60 on their web site. Can't find any info on a 2.02
