Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Spring Rate????
    Forum Member _Duke's Avatar
    Dec 2008
    New Boston
    209
    Default Spring Rate????
    Spring rates how do you know which is best for your application?
    I will be running coilovers with a 12" spring
    The car is extremely light. Right now with no motor I can pick up the front of the car so even after I add a ~600lb big block probably still looking at ~1000lb +/- a few on the front end.
    The car will only be used for drag racing
    Club Member monster.'s Avatar
    Mar 2005
    detroit zoo
    1,590
    Well, what is the spring rate currently. The easiest way to describe it is, if you increase your spring rate, you would increase the force it takes to compress the spring. If you decrease the rate, you get the opposite.
    Is this a road race setup, or drag. Spring tuning depends on what kind of driving you plan on doing.
    The only way around, is through
    Dec 2008
    New Boston
    209
    Currently a steel rod bolted in place of where the coilover will be, So that would be a pretty stiff spring lol
    bought the car as a project trying to get it going. It was previoulsy set up with a small block and don't know the spring rate.
    Drag use only
    I was thinking around 200lb springs???
    I figured I would through it out there and let the suspension gurus tell me if I was close
    Mar 2005
    detroit zoo
    1,590
    I wish there was a cut and dry value I could suggest based off what info you gave. Strictly drag racing, i'd go with a lower spring rate (front & rear) vs. a higher spring rate for autocross, etc.
    Shooting from the hip, and excuse the huge range, but for drag racing I've seen rates as low as:
    Front: 175lbs/in - 350lbs/in
    Rear: 85lbs/in - 200lbs/in
    To do it right, going to have to factor in rear spring rate and total vehicle race weight (driver, fuel, etc.) as well.
    What kind of car, that f-body? I'm sure someone would chime in with an F-body. I havn't tuned a GM suspension in my short existence on this planet
    Club Member JeffB's Avatar
    Dec 2003
    FLORIDA
    4,529
    What kind of car? I have 175# on the mustang in the front. I am thinking of putting 150# on. I have no clue on what I am doing though My reason is the front comes up real fast and comes down very slow. Maybe that is what I need? I want to lower mine in the front more too, sits a tad high for looks.
    Mar 2005
    detroit zoo
    1,590
    200lbs/in front spring rate would fall into that range. Chassis tuning is tedious to nail it down right. That would be a good rate to start at for sure, watch those corners though at 90mph.
    Mar 2005
    detroit zoo
    1,590
    Quote Originally Posted by lightning Jeff View Post
    What struts are you running 90/10, 150lbs/in would make it come up even faster. Adjust the coilovers for front ride height.
    Dec 2008
    New Boston
    209
    So it sounds like I'll start around 200 or so... What ever I can find a deal on
    Going in a 72 Vega Chassis Car
    http://motownmuscle.com/forums/showthread.php?t=109407
    Found these online...
    Gross Vehicle Front Spring Rate Rear Spring Rate
    Weight (lbs) (lb./in. approx.) (lb./in. approx.)
    2000 185 85
    2350 200 95
    2500 215 120-140
    3000-3500 250-350 150-200
    Spring Rate Total Weight on Front Wheels
    250 Under 1200 lbs.
    350 1200 - 1500 lbs.
    450 1600 - 2000 lbs.
    550 2000 - 2400 lbs.
    650 2400+ lbs.
    Club Member 1BADAIR's Avatar
    cardboard box
    28,361
    the type of suspension/location of the spring is the most important.
    a 1/1 suspension(like a true macpherson strut may not require as much spring as a long/ short arm suspension where the spring is about 1/3 the way out on the arm
    Dec 2003
    FLORIDA
    4,529
    Quote Originally Posted by monster. View Post
    It has strange adjustable struts, I need to adjust the coilovers to lower the front. Not sure if it will go faster, but it will look better. I snaped a pic of how it sits before I adjust them. My cell take some bad pic lately
    Attached Images Attached Images
