ill make ya famous...
WWW.JOHNQUICKRACING.COM
ya this is jason. i was gonna just weld a 3/8 plate on it i figured that would work
I don't know the exact situation you are encountering, but I needed to move the mount back on one of my cars. I had a stock cross member and cut the spot welds on the mounts, moved the cross member back and re welded it. Worked fine. Maybe this is an idea for you.
is there a generally accepted way to set the driveline angle? what should I be shooting for? I want to mount up my trans today as well, but dont know how much to angle it
Matt -
2010 Boost Logic GT-R
1983 Ford Fairmont
Two answers.
1. The least amount, and
2. the vertical angle (of both lines intersecting a horizontal line) to your axle pinion angle at ride height. If the pinion is 2 degrees nose up, then you want the trans centerline 2 degrees nose down. U joints vibrate due to the varying speeds as you spin a driveshaft, the object is to cancel the fornt joint vibrations with the rear. Putting the pinion and tailshaft at vertical angles creates cancellation of the vibrations.
FYI you also don't want the pinion and tailshaft directly in line either as this will not allow the needle bearings in the u joints to rotate and they will lose lubrication over time..
Hth
Last edited by beertestr; 04-19-2010 at 09:22 AM. Reason: wrote complimentary angle, meant vertical angle..
Mike
99 Ultra Classic, 89 Softail, 67 Kaw 250
K, Ive got the trans mount pretty much completed and the trans as far up as I can get it. The side connector is my limiting factor as its kind of bulky, but I am measuring about 5* from level on the damper. Is it OK to have the motor angled like this?
Ive also read that you need to mount the pinion a little negative to take into account for the bushing under load. I was told to give the pinion 3* negative angle to the angle of the trans. So I would be mounting the pinion at 2* from level if my motor is at 5* opposite
Matt -
1983 Ford Fairmont
Which motor are we talking about here? LS?? Which oilpan? FWIW PIckups with LS motors (factory not mine ) are mounted at 6 degrees, and the oilpan is designed with that in mind. I'll have to look through my list o'info and see what an F-body pan angled for. Either you should be fine, it might throw the dipstick reading off a bit but other than that no probs.
As for the 3 degree bushing thing, if you are running 1/4's all the time, that will help with u-joint loads on hard launches. Running down the highway at 70 is not putting a lot of reaction torque load on the bushings, you would likely have misalignment an possibly some vibration. Also, if you are running urethane bushings on the rear control arms, you can run less angle, as they deflect very little.
If you wanted some tuning options, set your x member up with a 1/4" spacer under the mount. That way, you have room to add/remove shims to play with driveline angle a bit.
If the connector is getting into the tunnel... well BFH's do wonders for that. Careful hammering can form a "Recess" that can be smoothed to look factory. I did that on my Caprice to fit the reverse lockout solenoid from the T56.. looked way better than I thought.
Mike
did you knock the tack welds off the tubes and slide the crossmember?
01 EXCURSION
11 RUBICON black ops
82 MUSTANG GT
75 Porsche 914
